Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony lcd tv 32 s 310
Suddenly the picture goes in slow motion ( as in special effects) also the color is showing extra tint of redness . can u help
SOURCE: Sony KF-50WE610 - red tint problem
I have the same exact problem. We found a temporary solution is to give the TV a "love tap" on the on the back beneath where it says "SONY." My guess is something is loose in the back. Make sure you don't hit the TV too hard and try different spots if one isn't working.
Posted on Mar 14, 2008
SOURCE: Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Posted on Mar 22, 2008
welcomejee
  • 10594 Answers
SOURCE: Picture with red 3-D effect
IC8001, STK392-560 seems defective, its convergence output IC.
Posted on Aug 06, 2008
My wega 50 inch TV is only 2 years old and is showing mostly a green background otherwise the same gorgeous picture!! Can you help??
Posted on Oct 22, 2008
  • 116 Answers
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
Dec 30, 2012 | Sony KDL-32M3000 32 in. LCD Television
I have a Sony Bravia KDL-32ML130. I turn on the tv and the colors are really red and the pictures seems like it's moving in slow motion. It does this with the Direct tv, dvds, and vhs. The sound is...
LCD Panel (screen) is defective and need to be replaced to solve this problem.
Click YouTube.com to watch similar problem in lcd tv that brought to my repair shop.
Thanks.
May 30, 2011 | Sony Bravia KDL-32ML130 32 in. LCD TV
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green...
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Jan 02, 2011 | Sony KV-32FS13 TV
The tv is at least 17 years old.The blinking red light blinks 5 times ,then the tv picture goes off . The voice is still on
Five blinks is the error code for an AKB (auto kine bias) error. What this means is that the set isn't able to balance the three color guns (red, green and blue) of the picture tube properly, and it's blanking out the screen.
To get the proper colors, the signals for the three colors need to be balanced, and Sony sets have circuitry to do this automatically. Other brands don't, and when they go out of balance you see a picture that starts to show tinting or colors that are off. As the picture tube ages, it gets harder to adjust the balance until finally the AKB circuit can't anymore, and poof, the picture goes away. With a 17-year-old tube, it's not surprising.
There isn't anything that can be done to fix the picture tube, it would need to be replaced. But the cost of the tube and the work required to get it set up after installation makes it completely uneconomical to repair this TV. A new picture tube is nearly $200. Then special tools are required to set the tube up (a process called convergence), so you'd need to find someone to put it in, and possibly pay to have the old one disposed of. A new 32-inch LCD set is around $350 now. Treat yourself to a new one.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Green tint to picture.
Are you using the componant connection on your tv? If so, check the red, blue and green cable connections on both ends. They carry your
picture info to the tv. The audio is carried by a red and white cable. There should be 5 cables for a componant connection. 2 reds, 1 white, 1 blue and 1 green. I hope I have guessed your problem correctly and this helps you.
Apr 07, 2010 | Sansui HDLCD-1900 19 in. LCD Television
Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Feb 25, 2010 | Vizio SV470M LCD TV
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Slow picture and dark reddish tint
These sounds like you have an issue with main board or tcon. Picture slow makes me think this is a communication issue between the tcon and the main board.... This needs a professional diagnostic. The good news is i don't think it is the panel which would make the cost of repair beyond the cost of the tv. If it is in warranty or just out of warranty call sony, sometimes if it is just out of sony's 1 year warranty they will make exceptions. But you need to call them for this exception.
Some solutions are not cut and dried and an on-site diagnostic is best. In your case this is true. I have worked on sony for many years and that symptom (at least the way it is described) is not one I have seen.
Oct 10, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
