Question about Nokia N80 Cellular Phone
Slide up, screen goes white but keys are active...
I had posted a startup problem of my N80 that it would stay in white screen even after powered up. Well it turns out the screen goes white only when I slide it up above the 3rd row of the keypad! It is working without much problems when the slider is not up. What could be the problem?
    Master:
  • 383 Answers
The strip that connects both the upper and lower slider is damaged ... replace it
Posted on Dec 11, 2008
Acer Aspire SA85 stays on Acer logo
Hi bob,
Usually system stops at the startup screen or the startup logo, when it finds some fault in detecting the IDE drives(ie,your harddisk or cd drive), if you dint get any get stuck in the logo, you have to see what happens at the background by clicking on f1 key or f12 or TAB or some key to show the activity rather than logo.....
After seeing the error we can conclude or decide about the problem, but when you were not able to see the screen after pressing any key as specified in your manual, Or it hangs after the LOGO screen, this must be problem with your harddrive, try changing the harddish or try connecting once again by removing it...
Enjoy Rate!
RNJ VINOD KUMAR
Jul 01, 2009 | Acer Computers & Internet
I have N70, I do have the problem of white screen on my mobile. It shows nothing on the screen except the white screen, even after making it several times ON/OFF it does not matter. So , kindly guide for...
had same problem on a n80 slide phone :found the ribbon conector in the phone had a split so only showed a totol white screen
Replaced ribbon cable and all was fine priced at only a few pounds
May 03, 2009 | Nokia N70 Cellular Phone
My N80 bring a white screen when i slide my phone
if you phone is less than a year old take it to car phone warehoue there will sort it out for free if not it will cost around 45pound ths pls rate
Mar 30, 2009 | Nokia N80 Cellular Phone
Nokia N80 Lcd screen
its a problem with ur Glex cable its the faulty part ion this case.
Dec 20, 2008 | Nokia N80 Cellular Phone
N80 White Screen
white screen?? but still your phone boots fine?can you still receive call or text msg? if soo, your only problem is the lcd of your phone,
but if your phone freeze on white screen and didn't continue to boot up, try reformatting it
by
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
but all your data will lost
Sep 01, 2008 | Nokia N80 Cellular Phone
Display problem in Nokia N80
It's a problem with the wiring that connects the upper part of the phone to its lower part when you slide it up. The wiring apparently gets damaged easily and you need to have it replaced, the wiring only, not the phone. This has also happened to me and I sent my phone to a certified Nokia Service Center. They replaced the faulty wiring but since my phone was still under warranty, they did not charge me anything. Hope your phone is still under warranty. Good luck.
Jun 13, 2008 | Nokia N80 Cellular Phone
N80 problem
I have nokia N80 and when i drag the slide i have a white screen
can some one please guide me as to how to fix this !!
Mar 17, 2008 | Lands Phones
White screen
i think ph internal phone memory is full, no space left even for bootup. For that u hv to format ur ph using *#7370# but b4 doing so plz NOTE U LL LOSE ALL UR DATA and remove memory card first.
hv fun ;)
shuweb
Mar 16, 2008 | Nokia N80 Cellular Phone
Nokia N80 problem
my problem with n80 is  next  when I open the slide the screen become like in 256 colors then i push the camera button and its come back to normal until i use  the phone when i close the slide the problem start again.What to do?
Jan 29, 2008 | Nokia N80 Cellular Phone
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Cell Phones Logo
237 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
