FixYa.com
Tags:
RCA DRC8295N DVD Recorder / VCR Combo
Dvd willnot record, keeps saying defect in disc
posted by jesicawabbit on Mar 05, 2007
I have done the reset, cleaning, ect... I also bought an exact same refurbished machine so I could finalize the recorded discs I did not finish up.. when I hit record (on both machines this happens) a msg says defect in disc is found the scheduled event was not recorded and this disc is beeing finalized to protect andy recordings on this disc (which there are none since it is totally balnk). I have purchased 3 different brand of recordable discs.. all have the msg pop up- here's the really strange thing when the old unit went out I had 6 discs that each had 1 movie recorde on them when I put them in the 2nd (refurbished) unit it was able to record on those discs. It will not record from VHS to DVD either same msg shows up, Yes I have checked & souble checked the connections, the first DVD recorder - recorded about 600 titles- so the connections r working did the same set up w/other machine. I am at a loss plz help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 25, 2007
Helpful (85)
hogfan
Rank:Apprentice Apprentice
Rating: 82%, 6 votes
immathews is correct. the manufacturer's service department confirmed that this model can not utilize 16x and said there is no firmware, etc. fix for the problem
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 10, 2007
Thanks for Trying (70)
PAPADAN
Rating: 70%, 1 votes
I WANT TO THANK YOU FOR THE POSTING OF THIS PROBLEM. I HAD THE SAME THING GOING ON BUT I HAD SOME DVD-RW THAT WORKED FINE SO WAS ON THE RIGHT TRACK OF THE SPEED PROBLEM. I JUST RECIEVED MY 8X DVD I ORDERED FROM TIGERDIRECT.COM AND THEY WORKED JUST FINE. I HAD TO ORDER THE 500 PACK ($89.99) BUT FIGURE I WILL USE THEM BEFORE I WEAR OUT THE MACHINE. AND OF COURSE THEY WILL WORK IN A FASTER MACHINE ALSO.
DANIEL HILL
Rating Locked! (?) jesicawabbit has rated this solution as Thanks for Trying
Solution #3
posted on Aug 19, 2007
immathews
I had the same problem and just figured it out about 5 minutes ago. I have been trying 16x discs. I guess it can only read 8x max dvd+r discs. Give that a try. The hardest part was finding 8x discs. I found some at K-mart on closeout, 15 for 6.00 plus tax.
Good luck to you.
Solution #4
posted on Jan 06, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Just wanted to agree with hogfan. Have been having the same record problems that have been posted. Came to the same conclusion that 16X was not compatible . Was looking for software upgrade, but none to be found. Maxell is he only brand that I have found that will work in record mode.
Paul
Can you Help with these DVD Players problems?
Will not read or play any DVD...
I place DVD disk in machine,... Answer This...
dvd freezes up
Dvd runs ok at first, then... Answer This...
Trying to copy a home video to...
Every time I try to do this, it... Answer This...
rca dvd recorder repair
where around zip 47529 can i... Answer This...
RCA VCR/DVD Recorder will not...
and, it keeps displaying,... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
