Question about GE Dishwashers
Dishwasher leaving residue inside unit after wash is complete.
It is a GE Pot Scrubber GSD3230Z02WW / Is there sometype of filter that I need to check? This information comes from an email a friend of mine sent to me referencing there dishwasher they utilize over the weekend. Thanks for the help. RH
  • 48 Answers
THere is a no filter on this unit just a strainer which is visible when opening the door.(its located near back on the bottom) You can take it off and check for pieces of trash or things that have made it by. The best idea is to take a few cups of vinegar (white) and put it in the soap dispensing door. Also take a big Glass and leave it upright and fill it with vinegar. Then run a normal load but dont use any other soap. ALso if your unit has a spot use Jet Dry or simliar products they really do help.
Goodluck
Posted on Dec 11, 2008
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
After the wash cycle is complete, it leaves a visible film on some surfaces (semi-gloss). Only a hand scrubber will remove this. It's an older model: AAU30000 Thank you.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Admiral Dishwashers
Our GE Dishwasher is brand new and everytime we wash dishes the dishes leave a residue of cloudy white in all of our glasses. What can we do to fix this problem? Thanks so much! This is our Model GE...
heatman101
Feb 12, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
WHY does my GE Adora GHDA656LSS Stainless Steel Built-in Dishwasher leaves residue on all the dishes after cycle completes? If its a filter problem, where is the filter?
heatman101
Nov 29, 2010 | GE Adora GHDA656LSS Stainless Steel...
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
My GE pot scrubber won't fill with water, all kof
you are probably in need of a new water inlet valve part #WD15X10003, should be around $35.00. this valve opens up at the proper time on the timer to let the water into the machine. hope this helps.
Oct 15, 2009 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
My dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Mar 01, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Open Questions:
Dishwashers Logo
160 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
