Nikkai USB-RS232 adaptor drivers for Vista
The accompanying disc doesn't include drivers for Vista, but the box says it does. Where can I download them ?
  • 1 more comment
  • teeseetwo Dec 19, 2008
    Thanks for the link. I'll try it tomorrow. I did my own "fix" in the meantime. For some unknown reason one of the 20 laptops I had to install on actually worked with the Nikkai RS232 adaptor, none of the others did. I found the installer puts two .sys files in the C:\Windows|?System32\drivers folder. I tried copying these from the one working laptop onto the other 19 laptops also using the blue CD, replacing the two .sys files, and if by magic, they all now work !
    Cheers, Tony
  • Anonymous Dec 29, 2008
    same problem it would not load into a vista pc but works ok on an xp pc
  • Anonymous Mar 22, 2009
    Thanks The Horseman. This worked for me. Had spent ages trying other sites. Cheers, Teddy
  • The Horseman Dec 22, 2008
    No problem, you are probably better using this driver as it was written for Vista.
    I found it by searching for the prolific driver for serial adapters instead of Nikkai, as they are the supplier not the manufacturer.
    It definitely works for me, I didn't want to mess around with manual install/copy of files, Not that I wouldn't be adverse to doing that either....
    Anyways thanks for the update and hope all works out for you.
Drivers for nikkai usb 2.0 tosata and ide adaptor
try to download it from topshare.com or in download.com
Dec 01, 2009 | Computers & Internet
Bought Nikkai USB to Parralel convertor for Samsung ML1210
if the cable have usb connector and the other end a ordenary centronics print connector then it wil works on xp and vista
have also try to connect a othe printer to connect ??
http://www.alternate.nl/html/summaryListing.html?searchCriteria=usb+to+printer&cat1=012&cat2=000&cat3=018
this cables always work
Aug 19, 2009 | Office Equipment & Supplies
Have just purchased a USB 2.0 to SATA HDD Adaptor made by Nikkai from Maplin. Have connected everything okay with my old HDD but when I go to run the 'Driver & User Manual' disc it just tells me it a...
Most of these adapters don't need windows drivers EXCEPT for use on a '98 system.
Got to the disk management console & see if your USB drive is there. It may simply need to have a drive letter assigned for you to see it in My Computer.
The path to the disk management console is usually: %SystemRoot%\system32\compmgmt.msc /s
Paste that into Start/Run.
Aug 12, 2009 | Televison & Video
Usb to rj45 adaptor driver needed
There is a good chance it is a realtek chipset
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=8&Level=5&Conn=4&DownTypeID=3&GetDown=false
Most of the usb to cat 5 / RJ45 adaptors I have come across have been this one
Tick the box download and try it there is nothing to loose and all to gain.
Aug 12, 2009 | Computers & Internet
My lap top can not find driver for usb-rs232 adaptor in vista
dRIVERS FOR vista at http://www.wiretek.com.cn/driver/USB%20TO%202%20x%20RS232%20Cable2/USB%20TO%202%20x%20RS232%20Cable.rar hope it helps
Jun 22, 2009 | Computers & Internet
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
I have an rs232 cable attached to kyrptview cable box via a usb adaptor.. Cant get my pc to see the box.. its a dell pentium 4 on windows xp.. any help pls
I assume the RS232 cable is going to a serial port? I think you should add a USB card to your system. The old async chips used to support RS232 ports are not fast enough to take USB info.
Mar 28, 2009 | Computers & Internet
Need drivers for nikkai usb to serial converter rs232
I purchased the Nikkai USB to RS232 adapter from Maplin and could not get the device working. (Maplin staff not much help!) The lead uses the Prolific PL-2303 device but Prolific do not supply the drivers to end users.
However I found the drivers that appear to work at:
http://www.cooldrives.com/wividrforprc.html
This then recognises the lead as a COM port. So far everything seems to work OK.
(Null modem check and basic 9600 data transfer.)
I hope that helps everybody.
Dec 08, 2008 | Computers & Internet
Nikkai usb serial convertor - no driver
i got the drivers from the prolific website (the manufacturers)
http://www.prolific.com.tw/eng/downloads.asp?ID=31
Dec 06, 2008 | Computers & Internet
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Computers & Internet Logo
5,747 people viewed this question
David Payne
David Payne
