Question about Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
Wi fi is not working
Aswin
  • s7027699 May 11, 2010
    You have to clarify when you say your wi fi isnt working. Tell the details of the situation.
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Tip
Blu-ray player wi-fi ready vs. wi-fi built-in
Blu-ray players are getting more internet capable and any player made 2010 or later is probably going to have wi-fi or wireless internet connectivity. However not all players are the same. Some Blu-ray players are wi-fi ready while others are wi-fi built-in. What's the difference? Wi-Fi ready players need an extra part called a dongle or adapter stick to make them work with your wireless router and not just any adapter, typically only the one the player's manufacturer offers. Usually this will cost you an extra $80. But Wi-Fi built-in players already have the adapter in them and are ready to go without adding a part. Be sure to check if the player is Wi-Fi built-in, as this is what you want for wireless connectivity.
on Mar 31, 2011 | Audio Players & Recorders
How do I determine what generation is my iPad?
on the backside of the iPad is a model number: determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-0.jpg determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Model iPad (1st generation) iPad 2 iPad (3rd generation) iPad (4th generation) iPad Air iPad Air 2 Picture 200px-ipad_1_psd_mockup.png 200px-ipad_3.png 200px-ipad_3.png 200px-ipad_3.png 170px-ipad_air.png 170px-ipad_air_2.png Model Number[99] A1219 (Wi-Fi)
A1337 (Wi-Fi + 3G) A1395 (Wi-Fi)
A1396 (GSM model)
A1397 (CDMA model) A1416 (Wi-Fi)
A1403 (Wi-Fi + Cellular (VZ))
A1430 (Wi-Fi + Cellular) A1458 (Wi-Fi)
A1460 (Wi-Fi + Cellular (MM))
A1459 (Wi-Fi + Cellular) A1474 (Wi-Fi)
A1475 (Wi-Fi + Cellular) A1566 (Wi-Fi)
A1567 (Wi-Fi + Cellular How to find iPad IMEI ICCID serial number
http://en.wikipedia.org/wiki/List_of_iOS_devices#iPad
Sep 21, 2014 | Apple iPad Tablets & eReaders
Receiving pictuer messages
I have had this same problem with Straight Talk before.
First, I would call them up because it would appears that sometimes, Straight Talk does not turn on the internet/picture messaging when doing the activations and they go amiss.
If you have wi-fi in your home or, if you are in a wi-fi hotspot, I would try sending a picture when you are own your own wi-fi or in a wi-fi hotspot. To do this, make sure your "Wi-fi" is turned "On" in the settings menu on your phone.
By having the "Wif-fi" turned to the on position, you can also save on your data usage by using your own wi-fi and various hotspots so you are not eating up your own data. I'm always surprised at how many people do not know this.
So check to see that "Wi-fi" is turned on in your settings and, send a picture over your wi-fi or a hotspot wi-fi. If you are able to send a picture over your wi-fi or hotspot wi-fi then you know that it's a problem with their network and at that point, I would cal Straight Talk and tell them that you are unable to send or receive pictures.
Jan 30, 2013 | straighttalk.com
How do I know if my iPad is an IPad 2 or 3
check the model nr. on the back side:
Apple Device Model Number
1iPad Wi-Fi (Original/1st Gen)A12191
iPad Wi-Fi/3G/GPS (Original/1st Gen)A13371
iPad 2 (Wi-Fi Only)A13951
iPad 2 (Wi-Fi/GSM/GPS)A13961
iPad 2 (Wi-Fi/CDMA/GPS)A13971
iPad 2 (Wi-Fi Only, iPad2,4)A13951
iPad 3rd Gen (Wi-Fi Only)A14161
iPad 3rd Gen (Wi-Fi/Cellular AT&T/GPS)A14301
iPad 3rd Gen (Wi-Fi/Cellular Verizon/GPS)A14031
iPad 4th Gen (Wi-Fi Only)A14581
iPad 4th Gen (Wi-Fi/AT&T/GPS)A14591i
iPad 4th Gen (Wi-Fi/Verizon & Sprint/GPS)A14601
iPad Air (Wi-Fi Only)A14741
iPad Air (Wi-Fi/Cellular)A14751
May 26, 2012 | Apple iPad Tablets & eReaders
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
Wifi saying unable to scan networks
Hello!
Here are the things you can try for a malfunctioing Wi-Fi on your Galaxy S:
Try turning off your Wi-Fi then turn it on again.
  • Sometimes, this works for me as the Wi-Fi might need a restart so it can try scanning again. You can do so by going to Settings > Wireless and Network > Wi-Fi Settings and ticking the Wi-Fi checkbox.
Turn off your handset then turn it on again.
  • An app that was running on your handset might be messing with your Wi-Fi, so to make all things better, you can restart your handset for a fresh boot. :)
Check if there are actually Wi-Fi networks in your area or the Wi-Fi is too weak.
  • If there aren't any Wi-Fi networks to detect, it can't do anything at all in the first place. Try moving to an area with better Wi-Fi signal.
You can ask me if you have any queries! :) ~azukibean70
Feb 23, 2011 | Samsung Galaxy S GTI9000 Smartphone
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
