Question about Dometic RGE400 Top Freezer Refrigerator
Dometic 2652 runs sparatically, then quit
Just bought fifth wheel and the frig started working fine. We had to work on the hot water heater and turned off breaker which also runs frig. When we turned the breaker back on, the freezer worked fine but frig wouldn't get cool. After a day or two, both the frig and freezer stopped working. Any possible solutions?
  • 62 Answers
If the burner area is geting hot its has a leak
Posted on Jul 25, 2009
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
My check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Apr 05, 2009 | Refrigerators
Dometic refrigerator inconsistent temperature
Yes the clearances on gas absorption frig is critical. Not to say there is not another problem. Is the thermister attached to the frig fins?
Mar 01, 2009 | Dometic RM2852 Refrigerator
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
207 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
