Question about Samsung CLX-3160 All-In-One Laser Printer
Making a funny noise as if it is not taking in the paper but it
Does. it makes this tick tick tick noise
anybody have an idea what is wrong with it.
it is a brand new machine
  • 1 more comment
  • valb00 Feb 17, 2009
    It also started happening to me after about 6 months of use
  • pardoc Mar 03, 2009
    I have the same.
    So far I assumed it is because one of the toner cylinder is not enough pushed into the machine, or tend to glide outside as there is nothing but the machine front door to keep them in place. So, the rear gear of the toner are not enough engaged with the one of the machine. So, it "jumps" over some of the teeth of the gear. It can damage both toner and machine gears --> I have to figure out how to actually fix those cylinder.
  • Anonymous Mar 20, 2009
    I have the same problem after 8 mths use. Samsung tech told me to replace toner cartridge(which I had just bought) as it may be faulty. I replaced the cartridge to only have the same problem. TRying to get it fixed underwarrranty.
I have found the issue with non-Samsung printer cartridges. I don't get the problem with Samsung cartridges.
Posted on Mar 12, 2009
My 2005 gmc Yukon makes a ticking funny noise when I first crank it in the mornings and it lasts about 3 Sec then return to normal..and a washing machine sound is coming from under the right driver side...
Balncer pulley or the other pulleys take the belt off and start it and see if does the same. The ticking noise you should see where it comes from when you take the belt off
Mar 06, 2013 | Cars & Trucks
2010 Honda Civic LX light ticking noise at Idle. 49000 miles on it. No Performance problems observed, But I was curious what the noise might be, And if Autozone can check the codes for anything wrong...
I doubt a "ticking" would cause a code unless it was something like a lifter sticking which may cause a misfire but your engine light would be on if this were the case. Now can you at least narrow down the area it is in like maybe one of the pulleys for your drive belt or does it seem to be in the engine itself. You can try taking the belt(s) off and starting the engine for a short time. If the "ticking" goes away without a drive belt(s) on it, then you need to find out what componant (alternator, A/C compressor, Power steering pump...you get the idea) is making the ticking noise. Codes are in most cases dealing with a sensor of some sort. Hope this helped you....
Oct 31, 2012 | Cars & Trucks
Hi! I tried to start my car (2000 Chrysler Cirrus) this morning, but it just makes a muffled growling noise an/or a ticking noise. My friend came by to jump start it, but that didn't work. Any ideas?
I could be wrong, but it sounds to me that your starter has just broke it's last leg. Many things can cause the starter to go bad. If all you hear is a ticking noise, then chances are that the starter gave up. You can have someone take it off and go to a parts store and have them test it for you, (some MAY charge you for this while others won't). This will tell you if your starter needs to be replaced. Be prepared. Considering the year, a replacement may very well be tastey expensive. Good luck. Hope this helps.
Oct 29, 2010 | Chrysler Cirrus Cars & Trucks
My camera lens won't go in and makes a funny noise everytime you try to turn it on. what's wrong?
my camera fell and tried to get the lens inn and now makes a funny noise and does not open
Jun 25, 2010 | Olympus FE-20 Digital Camera
95 Lincoln Town Car: Engine Makes Loud Tapping Noise
It has to be internal. Is it your valves or a slapping piston? (Sorry but internal engine problems are hard to diagnose without tearing down the engine)
Apr 30, 2010 | 1995 Lincoln Town Car
I was using my laptop when it threw up a message to turn it off then the screen went a green colour then blank.I have since tried to start it again but it is only making a funny noise.It is only 10 weeks...
I could go into a long explanation of how to troubleshoot the laptop but if it's only ten weeks old... take it back. if the noise you hear is like a ticking noise the hard drive may have quit.
robert
incidentally was that a blue screen or green
Nov 27, 2009 | Compaq Presario 700 470024-192 Notebook
Samsung CLX-3160 All-In-One Laser Printer Logo
121 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
