My Computer has two drives - C & D C drive has an OS dos D has Windows XP Professional Service Pack 3 My question is whether I can format seperately drive D ? Will the data stored in drive C become effected ?
  • Kamal Shukla Dec 11, 2008
    1 hard drive partioned in two. Want to format one partion. what about the data in the unformatted partition
  • 48 Answers
How many actual hard drives are in your computer? Open the thing up and take a look. You could only have 1 hard drive that is partitioned to look like 2. Just google image hard drives then look in you computer for how many you have. If they are different drives then nothing will happen to info on C, but if its 1 drive partitioned I would do further research.
Posted on Dec 11, 2008
  • Chaz G
    Chaz G Dec 11, 2008
    As long as you select the right drive (partition D) then everything in C should be intact.
    Goodluck and be careful and you should be fine.
Multiple OS problem[Primary corrupt]
Windows XP Professional SP2
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
if you need more help with this post a reply
hope it helps
May 25, 2012 | Microsoft Windows XP Professional SP2 for...
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
Can windows 7 run GTA IV.
Running GTA 4 on windows 7 should not be a problem. You just have to run the installer using compatibility mode. Right click on the "setup.exe" then choose Properties. Go to Compatibility tab and tick "run this program in compatibility mode for", choose windows xp sp 3. That should allow you to install GTA 4 on windows 7. Bear in mind that you have to install GfW Live and the C++ 2005 files seperately which can be found in the disk as well. More importantly, make sure that your computer meets the system requirements for the game.
Here it is: System Requirements
Minimum System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz Memory: 1.5GB, 16GB Free Hard Drive Space Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3 Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista) 18 GB Free Hard Drive Space Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
After installing the game and you're not able to run it, Try running the main executable file of the game in compatibility mode as well.
Hope this helps.
Apr 21, 2011 | Rockstar Games GTA IV
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
About service pack 3
Open this link and download the XPS file to upgrade to Service pack 3
Jun 30, 2010 | Microsoft Windows XP Professional
How to format os in compaq cq40-616tu os is windows xp sp3
If you not a professional, don't worry about it.
Follow these steps;
  1. Insert the Windows XP CD in CD-ROM/ DVD-ROM etc.
  2. Boot from CD-ROM and press any key when it required.
  3. Now press enter
  4. Press F8 when it will be required.
  5. Now select the drive C for installaiton of OS XP.
  6. Now choose format option FORMAT with NTFS or FORMAT with FAT (its your own choice)
  7. Now press F
  8. After formatting the files will be installed to copy on the disk and now in the end follow the instructions to installing windows.
Good Luck
Jan 26, 2010 | Microsoft Windows XP Professional With...
Install XP, it hangs up with the message at the bottom ''Searching for previous versions of Microsoft Windows'' please help
Windows installer always formats the disk after checking the previous installation. There are two ways to overcome this problem. One, if windows still boots, then insert the installation disk in the drive and let it Auto Run, and ask you whether you want to upgrade the OS or install new. If you upgrade then the formatting will not take place as windows knows that there is already a window on the disk. But should you want a new installation then it will do all the checking and may hang again. So, upgrade. Two, dl you have a DOS bootup disk. If yes then boot up with DOS boot up disk and format the HDD with it. once it had formatted and windows checks up, let it. It will not hang now. as there in a very clean HDD.
Nov 09, 2009 | Microsoft Windows XP Professional with...
How to format windowsxp professional service pack2?
you need to use the windows xp cd, in the setup one of the steps will format the hard drive, after that you will have to continue to install the windows or your computer wont start up anymore since the hard drive is empty.
May 21, 2009 | Microsoft Windows XP Professional With...
Uninstall xp
You can remove service pack 2 from within add/remove programmes, you will not lose any documents, but you will lose the udated security patches which is not recommended. If you mean you wish to remove XP SP completely, obviously the files and everything you have installed on c drive will be deleted as you can only save docs etc within an operating system, as c: is just a partition on your hard drive the files reside within the operating system. If you are upgrading to another operating system my advice would be to use a dual boot system and install the other operating system on a seperate partition of your drive, but you would have to have a fair knowledge of pc operating system installation processes.
Oct 03, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
