Question about Malber WD1000 Front Load Washer/Dryer
Whites come out yellow/brown after dryer is comepleted
I HAVE A MALBER WD1000 AND HAD THE HEATING ELEAMENT REPLACED, AND EVERYTHINGS TO BE WORKING FINE UNTILL THE WHITES COME OUT AND THEY LOOK YELLOW/BROWN AND I KNOW ITS NOT THE WATER. CAN ANYONE HELP?
Sounds like its getting too hot!
Posted on Dec 11, 2008
My Malber TD800 Dryer runs but will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rrtrt
Aug 22, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber 1000 Washer Dryer--Dryer doesn't heat
If this is still a problem, where is the red wire attached. Can you send a photo?
Jan 31, 2009 | Malber WD1000 Front Load Washer/Dryer
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
What was your solution???
I also had this problem. I looked on this site and before even opening up the machine, ordered a new heating element. After I received the new heating element which came with a service booklet, I opened the top of my machine. I started to begin the process of getting to the heating element(a very long process) when I noticed a red wire connecting to the thermostat was burnt and its plastic insulator was melted. I then pulled out the thermostat (a very long needle) and took the advice of Jagjared and opened up the thermostat and cleaned it. I then cut the burnt part of the red wire and connector off and stripped a small amout of the red wire and attached a new insulated connector that I purchased at the hardware store. I then reinserted the thermostat(which took a while because its hard to find the hole that the needle goes into) and then connected both hot and ground wires. I'm not sure what Jagjared meant when he said that he was able relocate the thermostat because I'm only able to place it exactly where I pulled it out. Maybe he can explain?? Anyway, this was a very easy fix. I think I'm pretty handy but would consider myself only an amatuer when it comes to issues like this. I think I might have had a very difficult time actually replacing the heating element so I'm glad I didn't have to. Hope this helps you all.
Apr 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000 Dryer wont heat
I have a bit of experience with Malbers. When the dryer won't heat the most likely cause is the heating element wearing out. See my other posts to the same problem by saerching Malbers problems here. If you need more help, contact me.
Mar 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
check two places. repair clinic dot com and parts select dot com
Sep 06, 2007 | Malber WD1000 Front Load Washer/Dryer
Clothes are still sopping wet when finished
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Aug 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
144 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
