Question about Sony PlayStation 2 Slimline Console
Hi there my ps2 slim won't read the disc the lens won't move or the disc if you press down on the led/top of the ps2 it starts moving the disc and lens and it reads could you help me
  • 84 Answers
Hi carlosca.
You could have some lint of hair stuck under the disc drive hub. look at closely to see and get it out.
The best thing is to know that the Slim laser has a plastic lens, and it will melt. Do not leave a disc in the powered up PS2 when your not playig with it. If you leave it running with a disc in the system and it is not reading the disc well, over time the Laser will heat up and melt the lens. If you posted this, how do you not have way of getting parts online.
Go to www.playstationclinic.com and call them to ask for parts you need, they will send them to you at a very reasonable price.
Posted on Dec 18, 2008
Slim PS2, disc not spinning
Well if there is nothing with the lens, i am afraid you're ps2's are garbage now. Your best choice is to sell it to some one, or throw it away.
Dec 09, 2009 | Sony PlayStation 2 Slimline Console
My son tripped over our friends ps2 and it fell to the floor upside down. The PS2 goes but the drive does not go.Any ideas how to fix this problem" Thanks
There are quite a few things that can cause a disc read error on the slim PS2. The most frequent is a bad laser, however, here is some useful troubleshooting info:
1. "Lid Closed Sensors" There are two "lid closed sensors" in the slim PS2. In a fall, it's possible that one or both have become damaged. Remove the top of the PS2 and try depressing both sensors with a game inside. The laser should move up and down at least???
IF YES, try again with the lid on... if the laser doesn't move when you close the lid, then the top casing of your PS2 cracked in the fall and is no longer depressing the lid closed sensors.
==> If the laser moves up and down OK but does not read discs, your laser was damaged in the fall. See below for a website with more troubleshooting info, pictures, and replacement cases and lasers.
http://store.richspsxparts.com/slpsnospdi1a.html
IF NO, you have a bad lid closed sensor -- these are not really replaceable easily -- you may be better off replacing the whole PS2 if one or both of these lid closed sensors goes bad.
Nov 17, 2009 | Sony PlayStation 2 Slimline Console
My Slim PS2 discs won't spin. I just replaced the laser...
put some wieght on the ps2 disk cover flap eg a game cover that fixed mine otherwise i would trash it man ;)
Jul 26, 2009 | Sony PlayStation 2 Slimline Console
My ps2 slim lens move foward and makes wierd and unusual noises it also doesn't even read any dvds
turn it on wait wen it makes de noise for a minute but wit no disc then open it move the lens back and forth very lightly if you do it to fast the ps2 might not read for a day or 2 when ur done moving the lens back and forth intel it don't move lightly any more then try a disc if it don't work do this process intel it works but wait 5 min before you do it again so the ps2 won't reck for half a day before you turn the ps2 off to do the process ithhis works for me 1st or 2nd times
Mar 14, 2009 | Sony PlayStation 2 Slimline Console
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Playstatiion 2 repair
Hi Jaybs,
The disc will not spin if the laser canot read the disc. you may have a dead laser or bad ribbon cable that runs from the Laser to the motherboard. I am posting a procedure to clean the lasers lens. I hope you do not have the Slim model, as this procedure is for the older Big size PS2. You do not use Alcohol on the lens of a Slim PS2 ,it tends to haze over the lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Disc won't spin... laser doesn't come on...
ok...well all of you people are just **** him! the actual problem is that you probably dropped the ps2 and the case lid got a bit lose...... what you have to do (if you dont want to buy a whole ps2 case again) is tap the ps2 on the top of the lid when it goes into the cd browser screen and it will work perfectly fine just make sure you dont tap i too hard or else we will have another problem...lol!
Nov 17, 2007 | Sony PlayStation 2 Slimline Console
Disc reading sound ps2 slim
Check around where the laser connects to the worm gear that moves it up and down. You may have some lint wrapped around the worm gear. Also check the disc spindle motor for Lint trapped under it. It could be your laser lens getting dirty.
Clean the Slims lens with a Q-tip and Window Glass Cleaner.
  1. Lightly Dampen one of the tips of the Q-tip with Glass Cleaner
  2. Swab the laser lens with the dampened Q-tip.
  3. Clean and dry of the laser lens with the dry tip of the Q-tip
Good luck
Nov 08, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 wont read any discs.
check the adjustment of ur cd holder, it might be very deep that causes the cd to touch the lens..coz lens usually move up and down, forward and back to read the cd...
Oct 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
100 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
