Question about Acer Aspire One AOA150-1570 Notebook PC
Acer not work
My Acer Aspire One no Turn on at all.
I try with battery or adapter power nothing.
I changed adapter but still nothing.
It's looks like total death. but ac/dc (adaptor) jack is ok.power LED also working well but no display at LCD screen
  • 1 more comment
  • t2thed60 Dec 28, 2008
    please help me fix this issue about this 5100 acer lap top computer built with in it windows xp.
  • lisafultz Jan 31, 2009
    I recently bought my Acer Aspire One online and I tried turning it on and it doesn't work! The power button lights up, and the batter button does too, and I hear an odd fan sounds to the laptop, but the screen is black! I really hope I do not have to ship it back because it will be expensive, but I spent $375 and I need it to work!!
  • Jason Edinger May 11, 2010
    When you press the power button, do you see any lights blink or hear a fan or hdd spin?
  • 7 Answers
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
  • 1 more comment
  • Harry Husted Feb 27, 2013
    Your link sends me here:http://ins26.blogspot.com/2013/02/lowest... Where is the correct place to get the BIOS update.
    When I follow your advice above, here is what happens. I hold the FN+ESC keys down. I push the power button down and hold it. I release the FN + ESC keys. The power light does not blink. It stays on steady. Any ideas.
    If I hold the FN and ESC keys down and hit the power button and release the FN and ESC key, and release the power button, the power light does not come on at all.
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
My acer aspire one wont turn on. the screan doesnt got switched on. pls help?
Does the power light comes on? Try a power drain. Disconnect the adapter, remove the battery, press and hold down the power button for 10 seconds. Put the battery back and the adapter and try to turn it on. Still no display? Take it to an Acer repair center.
Dec 21, 2010 | Acer Aspire One PC Notebook
I have an Acer Aspire 7736z which will neither turn on or charge. When I plug the power adapter into the laptop the LED light on the power brick turns off.
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Oct 24, 2010 | Acer Computers & Internet
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
I have an Acer aspire 5050 and when i try to turn it on i hear the fans starting but nothing hapens on the screen. i tried to conect it to a pc monitor but it didn't work. I think there isn't any video...
hello gligor,
try this.
Turn Off Laptop
Remove the Power Adapter Pin
Remove the Battery and leave the Laptop Idle without Power n Battery for about 2-3 Hours
Fit the battery again and connect Power Adapter and try again
Feb 04, 2010 | Acer Aspire 5050-3242 Notebook
I have ACER ASPIRE 2920, the power suplly can't turn ON
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Aspire One NO turn on at all
You need a DC Jack Repair/Replacement..
your dc jack is the port where your AC Charger plug plugs in to on the laptop.. They can Short out over time and the solder that connects the positive/negative pins burns off which causes the power to short out ... which in turn cuts off power connection to the laptop and can cause motherboard damage if not repaired..
Nov 27, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Acer Aspire 5520
check if dvd drive will eject if not
if it doesnt - try another socket
if still gets nothing - change fuse in plug
if same - try another power adapter (preferably from same manufacturer and model)
If still doesnt get power try get new power supply unit from repair shop or get quote for cost to fix
Jul 20, 2008 | Acer Aspire 5520-5908 Notebook
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
1,028 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
