Standard Registar SD650 Color Copier
Problem for Standard Registar SD650 Color Copier
What are the possible causes of paper misfeeds?
By maartenw - usenet poster
Solution #1
posted on Jul 08, 2007
Somewhat Helpful)
NALDZ
Rank: Wiz
Rating: 81%, 24 votes
clean the rubber on paper tray in clean cotton cloh with some drop of 70% alcohol...this rubber location where the paper feed...
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Somewhat Helpful)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
Paper misfeeds can be caused by the following problems: Using non-standard paper. Use standard paper and feed special papers through the manual bypass. See your operation manual for details. Damp or curled paper can cause a misfeed. Store copy paper flat in the wrapper in a dry location. Are there pieces of paper inside the copier? Remove all pieces of misfeed paper. Paper guides in the paper tray need to be set correctly. Set guides properly depending on paper size being used. Do not overfill paper tray. Remove excess paper from the paper tray.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jul 05, 2009
Not Rated)
chixenlegs
Rank: Apprentice
Rating: 0%, 0 votes
remove jammed paper from stack bypass, where is that located?
Was this helpful?
Yes
No
Solution #4
posted on Jan 30, 2008
Not Rated)
mj0147
Rank: Master
Rating: 91%, 21 votes
another possible cause.. check the pick up rollers..maybe worn out or dirty rollers.. cleaned the rollers using a semi wet cloth.
Was this helpful?
Yes
No
Solution #5
posted on Jun 20, 2007
Not Rated)
shaw
Rank: Guide
Rating: 87%, 7 votes
clean your paper feed tiers with rag and ceaning solvent
Was this helpful?
Yes
No
Popular Solutions for Standard Registar SD650 Color
Questions and Unsolved Problems for Standard Registar SD650 Color
Do you recommend Standard Registar SD650 Color Copier?
Answer
Answer
how to trun on a xerox copier
Answer
HP c4280 Photsmart paper feed causing jam. Pulling on right side.
Answer
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I... (More)
Answer
what is the cause of the stripes left by my scanner?When I scan to my web site, there are no... (More)
Answer
My cannon mp190 misfeeds and flashes E 2 on the LED what can I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Standard Registar SD650 Color...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
