Question about Canon PIXMA MP830 All-In-One InkJet Printer
HOW TO I TURN OFF THE SCANNER LOCK SWITCH - Canon PIXMA MP830 All-In-One InkJet Printer
    Sergeant:
  • 236 Answers
If you open the lid, the lock switch should be on the lower left corner.
Posted on Dec 11, 2008
  • 54 Answers
TRY TO READ THIS MIGHT HELP YOU
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
Where is the "scanner lock switch" located on a Canon Pixma MP980 printer? I cannot seem to locate the switch "under the hood" so I need assistance.
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp980#BrochuresAndManuals , in the Brochures & Manuals section. The current link to the Getting Started Guide is http://gdlp01.c-wss.com/gds/2/0300001552/01/MP980_GS_EN-US_V3.pdf . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Sep 21, 2015 | Canon PIXMA MP980 All-In-One InkJet...
What does E7 mean
  • E7 - Scanner locked error
    1. Turn the scanner off then move the lock switch to the "Unlocked" position. The lock switch is located on the left side of the scanner.
    2. Plug the power for the scanner directly into the wall, not in a surge protector or battery backup
Aug 18, 2014 | Xerox Documate Office Equipment & Supplies
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
Scanner locked, cannot copy
On this model, if you look where the copy paper comes out, just look underneath the scanner. There is a green slide switch with a icon of a pad lock closed and one open. Turn off the power first, then reach under and slide the switch to the unlock side.
Turn on the power and the machine should work.
Good luck.
Jul 07, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Workcentre M20i Scanner Locked, I tried flipping the switch still doesn't work.
I am not sure which switch you are talking about.
The machine has a power switch, and a scanner lock switch.
The scanner lock switch is located in the area where you take the copies out of the exit area, it is just above the knuckles of your hand. If you lean over look under the bottom of that scanner, there is a green sliding selector switch with a picture of a pad lock. Power off the machine, then move it to the unlock side. Then turn on the machine, see how it works ok.
Good luck.
Sep 26, 2009 | Xerox WorkCentre M20i All-In-One Laser...
SCANNER LOCK SWITCH IS ON...HOW TO GET IT OFF
Open the Document Cover - On the Front - Left hand side of the frame is the scanner lock switch.
Jan 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error 5020 scanner lock switch will not turn off.I am using printer pixma mp810
Does anyone know how to fix error 5020 release the scanner lock switch and turn the power off & on.The Cannon MP810 Printer. Please Help!Thanks
Dec 07, 2008 | Office Equipment & Supplies
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
393 people viewed this question
old marine
old marine
