Question about Cuisinart DFP-11 Deluxe Food Processor
Cuisinart DL 11: Cracked plastic drive shaft
Not sure how, but my wife and I have managed to crack the plastic "drive shaft" that turns the blades. The metal core is in tact, but the plastic housing has broken off. Can this be repaired? Easily? Inexpensively?
Thanks for you help.
Pat
  • Todd Diehl Oct 20, 2012
    I have the same issue, but have many accessories that I still want to use. What model can I buy that I can use the same blades & bowls with?. Thanks Todd Diehl
  • 8,596 Answers
If it is in warranty, it can be sent to Cuisinart for repair. If it is out-of-warranty, it will cost more than a new food processor to repair.
Posted on Dec 15, 2008
Cracked plastic sheath on the motor drive shaft
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
I need to remove the plastic motor shaft sleeve from my Cuisinart DLC10. THe old one cracked, I have a new one but the old one won't slide off...
Many people have had this problem. When I called Cuisinart, they said, oh sure we will send you the part and instructions. When I called because there were no instructions, I got another story about how I needed to send it back because that repair is only made at the warehouse. I have found other places online where people just chip and pick at the plastic until it comes off. Short of sending it back and paying the shipping I don't know what else to say. My husband is chipping and picking as we speak.
Jan 02, 2010 | Cuisinart DLC-10S Pro Classic Food...
The drive shaft extending vertically from the motor base has developed a crack. This runs from the top of the shaft down to almost where the shaft enters the motor base. The effect is to make the...
I just called Cuisinart customer service. Depending on your model, it sould be under warranty. They sent me a new shaft sheath immediately with no expense.
Dec 09, 2009 | Cuisinart Little Pro Plus LPP 3 Cups Food...
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
Plastic housing cracked Cuisinart DFP-11 Deluxe food processor
The Motor Shaft Cover parts are not shown on the Cuisinart website under parts, but they are available if you call Customer Service. These parts are quite inexpensive (often $3 + s&h). Have your model number ready, and they can get the right one out to you.
Jan 03, 2009 | Cuisinart DLC-5 Food Processor
Cuisinart does, in fact, have the replacement bowl parts for the DFP-11
Jan 03, 2009 | Food Processors
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DFP-11 Deluxe Food Processor Logo
409 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Donni Steen
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
