Question about Gestetner DSm622sp Digital Imaging System
Showdowing on printed pages
We replaced the Drum, but we are still having "shadow" images appear on the printed copies. The shadows are usually parts of the same page we just printed. Can't figure out what's causing it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Usually the Drum and the cleaning blade must be replaced together. Hope you done this already, if not replace the cleaning blade.
The problem can be in the fuser unit. Pleace check and replace the Hot roller, thermistor and HR strippers as a set and also the pressure roller bushings.
Posted on Jan 10, 2009
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
Shadow copy
Need a little more info but if you are using a laserjet printer shadows or duplicate images usually come from worn out rollers in your fuser. Depending on your model fusers are available by themselves or as part of a maintenance kit. Replace the fuser and that should take care of the problem.
Nov 02, 2013 | Sharp Toner Digital Copiers Ar M355 M351...
I have a 2002 Honda Shadow VT750c won't shift
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
83 Shadow VT750C Shifting Issues
Help 1983 honda shadow replaced startor wont shift Motorcycle Forum
Honda 1998 VT750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Sep 27, 2013 | 2002 Honda VT 750 DC Shadow Spirit
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
SAVIN NOT MAKING CLEAN COPIES
I don't know what model you are referring to, but regardless of that, you have a drum cleaning, and /or worn fuser roller problem
Mar 18, 2009 | Office Equipment & Supplies
Print problems with brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Shadow on printed page
You either have a bad toner cartridge or bad fuser. Measure the distance from and exact on image printered to the exact same spot on the page it appears again. If it's fuser it will be 41.0mm between image and defect. Any other spacing on the front of the page is usually cartridge.
Try replacing the cartridge first and if that doesnt fix the issue it's fuser.
Here's a link for the service manual. Look at page 117 to get a complete list on repetative defects and their causes.
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%201022%20(Q5912A),%201022n%20(Q5913A),%201022nw%20(Q5914A)%20P.pdf
Hope that helps you.
Aug 02, 2008 | HP LaserJet 1020 Printer
Double shadow image
YOU NEED TO CLEAN THE LASER UNIT happy faxing omnipresent
Oct 01, 2007 | Canon FAXPHONE L170 Plain Paper Laser
94 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
