Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Lg french door refrigerator new house no instruction book.
Where is the reset button for the new filter?
  • Anonymous Mar 19, 2014
    Just want to register it on line
  • 1,543 Answers
Press and hold the filter indicator pad for at least 3 seconds to reset.
Posted on Dec 11, 2008
Where and how do i change air filter for Kenmore 79673059410 refrigerator?
LG French Door Refrigerator - Replacing the Fresh Air Filter ...
? 1:26
https://www.youtube.com/watch?v=ziaCjNIPSCU
Dec 11, 2012 - Uploaded by ExperienceLG
LG French Door Refrigerator - Replacing the Fresh Air Filter ....DO NOT GET THIS FRIDGE UNLESS THIS ISSUE IS FIXED!!!! We've had this ...
Jan 12, 2016 | Kenmore Refrigerators
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Icemaker fill leaking on new LG LFX28978SW french door refrig
Do you have the "dummy filter plug" installed and not the actual water filter in the upper left of the inside of the fridge?
Jul 01, 2010 | LG Refrigerators
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
Lg french door fridge
do you have mechanical button switch that should close the light if you close the door?... they could be defective. try to look for these button switch that the doors presses as you close them. if they dont have, then they may be using a magnetic door switch which would be very hard to locate and trouble shoot.
Nov 20, 2007 | LG LRFD25850 French Door Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
359 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
