Question about Video Game Consoles & Games
I need a power plug for genesis sega model # 1601 thank you
  • camw Jan 15, 2009
    thank you I have found a cable
  • 3 Answers
I believe for model 1601 it is a 9v 850ma power Adapter
search those specs online....there are many sites that carry that adapter. Just make sure you get the cord for model 1 (1601).
This website carry's it as I am sure several others do as well.
http://www.nintendorepairshop.com/shopexd.asp?id=336
Posted on Jan 12, 2009
  • artbysmith Jan 16, 2009
    Strangely enough I also have the same problem now as I can not find my power adapter for my modle 1601 genesis. So i will have to check the website I mentioned in the previous post here and order one for myself.
    and to note my Genesis Model 1601 says what power cord to use for it on the bottom of the console. Mine states to use model model 1602 adapter....9v 1.2 Amp so I guess it varies from model to model so check your specs on the bottom of your genesis console...it should say there what you need to use.
    Assistance not needed, just best way to reply and state another option
On/off switch replacement sega genesis 1
you need to call Sega at 1800-842-7342. This is Segas phone number see what dose it cost to repair the genesis.
Jun 13, 2012 | Sega Genesis Console
Missing the part that plugs from console to television where do i find?
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 29, 2011 | Sega Genesis Console
We just purchased a Sega Genesis 16 bit sysyem...Model 1601. We do not have hook-up instructions. Would you be able to help us?
Wow, that is a pretty vintage little game system you got there, but sure I can do the best I can blindfolded.
you should have gotten a A/V cable that ether has a RED/WHITE/YELLOW or a RF Co axe end.
If you got a A/V what you do is hook that to you TV where it says input.
If you got a RF coax you would need to hook that into the round cylinder input with a hole in the middle.
If its AV the tv would need to be put on input. If its the other the tv would need to be on channel 3.
Whatever the case may be please update me if you have any other questions.
Kind regards
Rulds2008
Jun 15, 2011 | Sega Genesis Console
Wont come on
Man I haven't seen an actual Sega Genesis console in years. Anyways...
1) Make sure that everything is plugged into your system properly. 2) Check you make sure your TV is on the right channel 3) Check to make sure the fan is at least powering up when you turn on the Genesis. If it is then the Genesis is working. 4) Plug something else into the TV to make sure it works.
Remember, HDTVs and LCDs and this whole Al Gore's Gone Green thing wasn't around when they made the Sega Genesis, so conventional means to playing a Sega aren't your best option. Don't plug it into the wall either, make sure you are plugging it into a surge protector.
Hope this helps.
Jan 01, 2011 | Sega Genesis Console
How do i install a sega genesis 16 bit to my tv and what kind of cords do i need
Sega genesis has a proprietary plug which goes to a standard RCA Style cable. They go for about $9 on eBay.
Or you can get one from Amazon here.
Apr 29, 2010 | Video Game Consoles & Games
Sega Genesis not displaying correctly
mine did the same thing. check the video cable, make sure it's in good condition and try to repair RF switch as best as you can.
Jun 24, 2009 | Sega Genesis Console
Can't seem to play the games
Sounds bad
the contacts for the carts may be worn
get a credit card, cloth and head cleaning fluid.
put the cloth around the card and a few drops of liquid and push in to the slot and clean the contacts.
make sure none are bent out of place.
if cleaning won't help then you may need to open up and look at the contacts for dry joints; a blob of solder may help.
failing that you may need to look on ebay for a replacement console (you won't need the leads so it shouldn't cost more than a tenner including postage)
Oct 10, 2008 | Sega Genesis Console
I have a sega genesis. i hae no look how to hook it up. please help me.
well a sega genesis there are 3 different models all either using RF adaptors or AV cables
if RF adaptor please follow this
plug the RF adaptor into the back of your tv the coaxal cable for your tv service ushally runs through this, and plug it into the the back and you can also plug the service into the RF adaptor for the sega genesis. plug the power in and make sure you are on the correct channel (3or4)
If you are using AV cables please advise and I will post the following for that.
Aug 11, 2008 | Video Game Consoles & Games
Line across top of screen
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Jul 02, 2008 | Sega Genesis Console
Sega genesis
don't panic
sometimes the LED goes on the Megadrive
so try to tune it in anyway. (clean a game and put it in)
also sometimes you can get a "Dry joint" at the power port at the back of the megadrive.
this is fixed by unscrewing the megadrive and a little solder on the each of the 3 joints.
May 19, 2008 | Sega Genesis Console
Video Game Consoles & Games Logo
43 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
