Question about Blaupunkt TSc50 Car Tweeter
Tweeter problem i got a new set of tweeters that has a crossover on it but i don't know where does the red+/red black- wire goes can u help me.
    Problem Solver:
  • 14 Answers
They are the wires that connect to your audio device. lots of people run them on amplifiers,but you can connect them direct to the stereo speaker outputs becouse they have built in cross overs,but make sure you connect the + and - mires round the correct way.check your audio wires to make sure you get this correct
Posted on Mar 08, 2007
Tweeter no sound but speaker no problem
In the most general, basic sense, I would be assuming that this is just one speaker and not 2 with this problem, or 3 or more.
Only way to get the ball rolling is pull the tweeter from the cabinet, checking to make sure all wires are connected at the tweeter and inside the speaker.
If that is the case, then you would need to determine if this is the tweeters fault, or its crossover (thing that divides the sound into whats right for the woofer and what the tweeter wants).
If you have a multi-meter, you would disconnect the wires from the tweeter, set the meter to ohms and touch a probe to each speaker terminal. No action means burned out tweeter, 100% action means burned out tweeter, a reading slightly less than the rating on the back of the tweeter (for instance an 8 ohm tweeter would show anywhere from 6 to 8 ohms on the meter) means tweeter is good.
If you have no meter then take the tweeter from the good speaker and swap in place of the bad one, making sure you respect + and - connections.Its a little risky this way,since if there is something wrong in the speaker it may hurt the good tweeter..(the meter is the safer bet). If it works, then you need a replacement tweeter, if not the problem is either wire connections inside the speaker, or something is wrong with the crossover.
Nov 03, 2014 | Audio Players & Recorders
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
How do i tell if my problem if the high freq diaphram or the cross over
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Apr 02, 2011 | JBL PRX515 Speaker
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
I have A RXC 216 crossover and want to run 2 RTC 19 tweeters with this crossover, is there going to be anything wrong in this set up?
Yes and no. First I'll start by saying that the crossover should not be effected and the crossover frequency (meassured in Hz.) will not change either. What you will be doing is either doubling, or reducing by half, the effective impedance of your tweeter. If you wire the tweeters in parallel the impedance will be cut in half (car audio speakers are typically 4ohm), the result will be a 2ohm load. Most car amplifiers are "stable" at 2ohm, but sound quality will suffer. The other option is to wire them in series, this will double your effective impedance meaning an 8ohm load. With a higher load the amp will not put out the same wattage ( the lower wattage will most likely be undetectable). Hope this helps!
Jan 27, 2010 | MB Quart RTC 19 Car Tweeter
How do you install dome tweeters?
tweeters get installed almost like any other speaker. you pick a mounting spot, then mount them, or cut the hole for recessed tweeters, etc. run the wire to the closest speaker wire from your stereo, and just splice it in. you will however need some kind of crossover to prevent the low frequencies from being played through the tweeters. if you buy new tweets, they usually come with their own crossover, or there are a few different styles you can get.there are the passive crossovers, the ones that look like small boxes. there are also the inline filters. these are the ones that you splice into the positive speaker wire to filter out the low frequencies. and some aftermarket stereos come with some kind of filter or equalizer built in, depending on your model. what I would do is buy one of the inline filters for each tweeter. theyre inexpensive, and easy to install, and they work great. so basically, just mount the tweeter, run its wires to an existing speaker wire and splice it in, and install an inline filter on the positive wire for the tweeter. oh, one last thing. if your interior speakers are powered by an amplifier and not by the stereo, then just run the tweeter wire to the speaker outputs on the back of the stereo. too much power will definitely destroy any tweeter. good luck!
Sep 08, 2009 | Car Audio & Video
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
No sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Apr 28, 2009 | Jl Audio VR650-CSi Car Component System
Blaupunkt TSc50 Car Tweeter Logo
56 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
