After the machine starts to empty,the dial starts to rotate
The washing machine is a candy model CN166T.80 made in 2005 and it will start on wash ok.drum rotates and heats up ok,but as it starts to pump out,the prog knob starts to rotate
  • graham_coope Dec 18, 2008
    many thanks for helping with this. My customer got fed up with me taking so long,and i think he went to hoover in the end.
    These computer machines really need the right diagnostic equipment to fault find them,so sometimes i am going to have to walk away from them.
    kind regards, Graham
  • Nicesuit
    Nicesuit May 11, 2010
    could be a couple of things, the dial could be faulty or the board or the thermostat, all machines have a timer function to complete a task within an allotted time if it does not make it in the time it will cancel the program and empty the water. you may have to bite the bullet and get one of the Hoover/candy engineers to plug a laptop into it it will cost around £90 to get them out but you will get a guarantee on any repair for a year. cheaper than a new machine?you have free parts on these machines for five years
Thanks, I think the customer called in Hoover in the end,as without diagnostic equipment
its very difficult to find whats causing the problem,cheers ,graham
Posted on Dec 18, 2008
Why does my candy grand o washing machie say 08 and stop working
If the code actually is E08, there is a problem with the motor speed sensor. The motor may be rotating at high speed for a few seconds, slowing down, and stopping or there may be no rotation at all.
Feb 24, 2017 | Candy Washing Machines
How do you cancel wash cycle on candy do df 800 the programme is stuck on filling up so have turned water supply off but cannot cancel programme
Good evening Julie
you have problems with your Candy, so have I with mine.it is mostly when I am starting a drying program, that she starts washing again. Then I :
  • turn the machine off
  • Wait 3-5 minutes
  • Turn on emptying
  • Wait 3-5 minutes
  • Turn on spinning
  • Wait 3-5 minutes
Try this way, turning the machine off, waiting and over to the programme you want.
good luck
kolbrun
Aug 12, 2015 | Candy Washing Machines
Candy washing machine gc4 2d washes for about 15" then stops for 30" (the screen goes black) then on again for about 10" and then stops again.
sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
Dec 06, 2014 | Hoover Genuine Candy Zerowatt Washing...
Candy CNW156 washer/dryer: spins empty, won't spin under load
If the belt and the motor are OK, then tell your friend to check the motor coupler, the MCU (motor control unit).
See also the following link : It doesn't spin.
Dec 01, 2008 | Candy CNW156 Front Load Washer / Dryer
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Programme dial
that is your only solution but u might find u can buy a second hand machine that works for u to get parts off this will proberly be cheaper than buying a timer thats what id do u get more for your money m8
Aug 14, 2007 | Candy AQ130 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
