Question about EliteGroup 648FX-A Motherboard
Bios is not loading up
How can i solve that bios is not loading up?
  • 104 Answers
Try resetting the cmos jumper and see if that works, it could be a number of things, such as the cpu or motherboard itself
Posted on Dec 11, 2008
  • 2,110 Answers
Try to change CMOS BATTERY on the mother board..
Installed new bios for windows 7, not working,on start up, computer locks up, able to unlock- but didn't happen with original bios. Looking for old bios to re install
o open the BIOS Setup screen: Reloading the BIOS default settings To reload the factory BIOS settings to the setup default:
  1. Press the F5 function key.
  2. Select Yes or OK.
  3. Press the Enter key.
  4. Press the F10 function key.
  5. Select Yes or OK to save the defaults.
You can also complete the following steps to reload the factory BIOS settings using the menu:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults.
  3. The system prompts you to load the optimized setup defaults. Select Yes or OK and press the Enter key.
  4. Select Exit Saving Changes.
  5. Press Esc and then press Enter to exit Setup.
Please don't forget to rate this if it fixed your problem. Four thumbs up is basically what means your problem was solved. Anything less means your problem was not solved. Not sure people here understand that as far as how we get rated.
Cant show my pen drive or any input from from external sources,seems it was locked in the bios .how can i solve it
If is something related to the BIOS, enter to BIOS and choose : Load Default Settings, Save and Reboot.
To Access the BIOS: Tap F1, F2, delete key or F10 just after rebooting your computer
Hope that this help
Dec 17, 2010 | Gigabyte GA-945GZM-S2 Motherboard
I had installed one software that was bios update after installation that software Hp pavillion dv2000 bios configuration had chage. how can i solve this problem now my laptop cant detect the harddrive. it...
Restart your laptop, and immediately press DELETE to enter BIOS setup. Select "Load BIOS Defaults". Navigate through the menus;
you should see "auto-detect disk-drive". Run that utility.
Save the updated BIOS settings, and exit from BIOS-setup.
If all else fails, take the computer to a qualified technician.
It's probably just a 10-minute "fix" for an expert.
Nov 20, 2009 | Dell Latitude D600 Notebook
I lost the drivers and my bios is corrupted
yes you need to go to the manufactures website load the bios to a usb drive and flash the bios
Aug 21, 2009 | Computers & Internet
Problem on loadind windows xp on hp pavilion dv2000 laptop
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Nov 29, 2008 | HP Pavilion dv2000t Notebook
Bios setup
most easy way is to enter BIOS and load either the default values or the optimized values. Than select save and restart.
Aug 05, 2008 | Computers & Internet
Booting problem
If you have flashed your BIOS, you need to go into bios and select load optimised or default settings, reboot then go into bios and check the boot order of the HDD to ensure the HDD with the OS is the first boot drive
post back results and I will try to assist you more.
Jul 13, 2008 | ASUS K8V-MX Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Acer descktop t-180 stuck on "verifying DMI pool DATA"
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
Jan 06, 2008 | Acer Aspire T310 PC Desktop
EliteGroup 648FX-A Motherboard Logo
279 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
