Question about HP Compaq nx6110 Notebook
Keyboard not working
I was using windows 2000 than i up-grade to windows xp
then my spacebar on the keyboard stop working but all keys working fine.
  • 64 Answers
It sounds like driver problem. Download the drivers from HP website.
Posted on Dec 12, 2008
Wired and onscreen keyboard space bar doesnt work
Keyboards are cheap. If you need to use this one then you will need to carefully pop the spacebar key out, turn the keyboard upside down and give it a good shake. You will see a ton of junk fall out ;)
Mar 08, 2014 | Computers & Internet
Logitech DInovo edge spacebar not working
try to remove dust in your keyboard by using paint brush or compressed air.
Nov 05, 2013 | Logitech diNovo Edge 9676850403 Keyboard
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
My neo basic B2165 laptop keeps long constant error tone while turn on and freeze on booting(and error tone doesnt stop), you have to press del or @ keys to stop error tone and continue to boot up and...
Since you have reinstalled the OS and it didn't fix the problem. It most likely your computer having one or more hardware failure. You need to check each of your computer component to find where is the problem.
Feb 28, 2011 | Computers & Internet
I am trying to format my virus rdden computer, however when I get to the point of accepting the agreement with windows (after booting from the cd) it won't allow me to accept. what do I do?
Generally this occurs when F12 is pressed multiple times causing the keyboard to stop responding because the keyboard buffer is full.
At boot, when the Dell Splash Screen Appears press the F12 key once when the progress bar is 70% across the screen (System should beep ONCE) then select the optical drive and press spacebar when prompted. The keyboard should work fine after that.
Feb 25, 2010 | Microsoft Windows XP Home Edition
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
I have GA945GCM MOBO. While booting it gives continuous beep. If any keyboard key is pressed it stops. The keyboard spacebar key is not functioning. After boot in windows XP, the keyboard problem (spacebar...
Hi shreepad,
Those sound like you have a bad memory chip DRAM or it may not be seated correctly. The beep code of 1 long beep, also indicates a bad memory chip. If you have two or more, take one out and until you find the one that's bad. Then replace it.
Good Luck
Nov 24, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
The spacebar doesn't work consistantly unless ''pounded''
The spacebar is the most often used switch on your keyboard, so, yes, it's from overuse, but also from
the fact that it is the longest key on your keyboard and the closest to the edge, all of this combining to
make it the dirtiest key on the board.
So, get a keyboard cleaning kit, either professional or DIY which would consist of the following, cotton
swabs, compressed air, and maybe a toothbrush and realize that all the stuff that accumulates under
your keyboard's space key makes it harder to depress to the point where contact is made.
Apr 11, 2009 | Computers & Internet
use a compressed air can to clean under keyboard.
Jan 11, 2009 | Packard Bell Easy One Silver 2120 Notebook
HP Compaq nx6110 Notebook Logo
138 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
