Question about Sony DSC-T7 Digital Camera
DSC-T7 Locked up "USB Mode Normal"
Hello, I hope someone here can help me. I am going crazy!! My DSC-T7 was working find and all of a sundden in the middle of taking a bunch of pictures it started to go back and forth between the normal picture taking screen and "USB Mode Normal" screen. I tried to turn it off and on a bunch of times and it is now worse! at the moment: when I turn it on, it showes the battery power on the left top corner, mid top it will say "USB Mode Normal" under that there are four white dots and at the bottom it says: "Switch on MENU". If I press the menu botton, everything stays the same except the lower left corner, inside a yello box will say: "USB Connect". pressing menue will toggle between these two screens. non of the other bottons do anything. I took the mem stick out and turned it on still the same. I took the battery out and put it back in with the same results. has anyone run into this? can anyone help? Please and thank you.
  • Anonymous Oct 08, 2013
    Yes, it's an old camera, but my mom gets use out of it. Now, after all this time, it too, is locked into this mode. Has anyone found a fix? I can get to the Access creen without any printer hookup, but just can't get out of USB mode at all. Is there a keypress combintion to do some kind of factory reset? I really do need to fix this. Thanks.
I am a user with the exact same problem as you desribed for my DSC-T7. My problem started when I splashed two drops of water need the battery door and then the camera would not power up. I removed battery and card for a day and camera worked fine for another day. The following day, I left my camera in my sun visor of my car for the day (>90 deg F outside) which I forgot that I put it there. The next day my camera did power up in the locked mode exactly as yours. I do not know if it was the water drops or the heat but it is doing exactly as you desribe. However, here is something that I have discovered while trying to get the camera to work: 1. I plugged the adapter into the side of the camera since I am concerned that the USB port is the issue. 2. I plugged the USB cable into my portable printer and powerer the printer up and then turned on the camera in all three modes to see if anything changed and it did not. 3. I have found if you turn off the printer with the USB cable still in the printer and the adapter, the camera then enters a mode that shows thw word "ACCESS" and then the camera works perfectly. All modes of the camera work fine. But as soon as you power up the printer or remove any of the cables or remove the adapter the camera reenters the locked mode. This is not a solution but an indicator that the USB port is possibly causing the problem but not sure why the printer being off causes the camera to work fine. In addition, have all of the cables hooked up and to the printer does not allow the camera to be used with any mobility but wanted to let you know what I have discovered and hopefully maybe this may lead to a potential solution. Steve
Posted on Jul 31, 2007
2 Suggested Answers
  • 883 Answers
SOURCE: DSC-T7 Locked up "USB Mode Normal" Second user with exact same problem!
can you find a reset switch? look for a tiny access hole to insert a pin...possibly under battery.
Posted on Jul 29, 2007
I have a Sony Cyber-shot DSC-T7 Digital Camera how can I reset it
To reset camera follow below procedure:
Press MENU, select SETUP, select SETUP1 and select INITIALIZE and press OK to reset DSC-T7 camera.
Hope this info will help you.
Thanks.
May 22, 2010 | Sony DSC-T7 Digital Camera
Im going crazy looking for a site where i can download a usb driver for my cybershot DSC-W55! Please help :( x
copy and paste URL.
http://driver-pro.com/related/english/hardware-drivers/?a=16646&gclid=CJGR6o2y250CFU1M5QodyEsZyw&e=1&hit=1
and follow instructions. I hope this helps
Oct 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I dont have a usb cord for my cybershot dsc t7 do i need one to add pics on my pc or do i need to install the memory card in
its a personal prefrences really. i prefer connecting my sd card but some prefer the cable. bottem line is its up to you whicever you like better both of them work equally as well. for an sd card reader follow this link:http://www.newegg.com/Store/SubCategory.aspx?SubCategory=69&name=Card-Readers for a usb cable: http://www.newegg.com/Product/Product.aspx?Item=N82E16812339141 good luck please rate!
Aug 09, 2009 | Sony DSC-T7 Digital Camera
Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Mar 12, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Not powering on???
To reset, take battery out, hold on power button for 15 seconds, let go afterwards, replace battery
Dec 15, 2007 | Sony DSC-T7 Digital Camera
I went to the technicall service.They fix it. They told me i had water inside (humidity) they have clean the chips, formated again (they said)
90 minutes of hand work= 72 euros.
You may try to open it and with a hair dryer?¿?¿?¿
Now is working properly, but I have 70 euros lessin my pocket..
Good luck
Jul 29, 2007 | Sony DSC-T7 Digital Camera
DSC-T7 Magnify Mode
Hello, Don't mix magnifier mode and expanded focus mode. Magnifier mode is simply a short AF range operating mode, like a kinda super-macro. Whether you selected mag/macro/normal, the camera operates always same except that the focussing range limits are changed accordingly by the S/W. The lens itself is capable of focussing from 1cm to infinity anyway. Expanded focus is used on some still and video cameras to assit manual focus because the LCD's resolution is lower than the CCD's. It can be seen as a workaround for the lack of optical reflex viewfinder (Sony cams ar not dSLRs, including HDR-FX1!). So the center area of the pic is "digitally zoomed" to make sure you can adjust a sharp focus of the point of interest in your frame. However it has nothing to do with macro shooting, and works at any distance within the lenses focussing range. Hope having helped
Sep 12, 2005 | Sony DSC-T7 Digital Camera
DSC-T7 Blurriness
Try this test: Mount the camera on a tripod or set it on a secure base and use the self timer to trip the shutter. Doing this will totally eliminate any possibility of camera shake causing blurriness. If the picture is still blurred then there might be a problem with the AF but if it isn't blurred then the problem is either camera shake OR subject movement (or both).
Sony DSC-T7 Digital Camera Logo
110 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
