Question about Yamaha HTR-5650 Receiver
Audio output Voice comes from the front  left & right speakers and the center speaker all at the same time.  Used to be that voice came mostly from the center speaker and other sounds from the front left & right speakers.
    Problem Solver:
  • 5 Answers
I have the same issue if I connect my digial audio cable from the Yamaha receiver directly to the HDTV. But, I get all 6 speakers working when I connect the Yamaha receiver directly to the Comcast HD box (instead of TV).
Posted on Dec 26, 2008
How do I change the DVD audio back to hearing the voices and not just background noices on the movie
Most voice tracks come through the center channel. If you don't have a center speaker hooked up, then turn off or change the surround mode so that the player will put the voice tracks back to the front speakers.
Nov 15, 2016 | Televison & Video
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
On my stereo doesn't output the voice
Do you have a center channel speaker hooked up? Most voice tracks come through the center channel
Oct 18, 2013 | Onkyo Audio Players & Recorders
The navigation voice has no audio on my pioneer AVIC D3
voice only comes out thru the front speaker, if you hook up amp to rear rca, change to fronts. also speaker outputs, too. btw, did you turn on the voice/volume at the menu??
Dec 16, 2009 | Pioneer AVIC-D3 Car DVD Player
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
Just wire one voice coil each into left and right rear respectively, in series with the original rears or if this is too quiet, wire both voice coils in parallel together and connect as per original single coil unit.
As they are 4ohms each they can simply be connected as simple speakers on each rear channel output, since thats exactly what they are, capacitors are used inside to make them react to bass frequencies only. Wiring them up is no different to wiring up a pair of 6x9's.
Oct 24, 2009 | MTX Thunder 4244 Car Audio Amplifier
No voice
Check your "main menu" settings. If you are not using a center channel you need to go into "speaker settings" toggle to "center channel" and select "none" If that's not what your question is, post a comment with some more detail and I will gladly help you more. Hope this helps.
Sep 04, 2009 | Yamaha RX-V461 AV Receiver
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Yamaha HTR-5650 Receiver Logo
111 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
