Question about Dryers
CDT00 Drying takes ages, water tank does not fill
Hotpoint CDT00, checked heater elements they seem fine, but takes ages to dry, when cleaing filter and housing, dust etc in the housing seems damp. It would seem to me that it is not condensing and therefore recycling the moist air hence the time being taken.
If this is the case how can I prove it?
How do you get at the condensing element to change it?
    Scholar:
  • 61 Answers
Check all seals are clear and free from dirt, also there will be a heat exchanger (usually located above the sump) this must be clean and free from dirt this does all the work so if the area is not clean it will take longer to dry.
Posted on Dec 11, 2008
I have a hotpoint mfg#HDA2100VCC brand new and its leaving this brownish film on the residents dishes. Everything cycles fine and ive checked her water to make sure it isnt hard or carring rust deposits...
those dissolving detergent packs are the cause of 80% of warranty pump failures. i have even seen them wedge under the heating element and catch fire during the drying cycle. it could be from the detergent. but most likely it is from iron deposits in the water that you cant normally see that oxidize during the drying cycle. install a simple filter on the water suppy, change to a liquid detergent, and run the diswasher with some vinegar inside a few times after installing the filter.
Sep 26, 2013 | Hotpoint Hot Point HDA2100VCC Built In...
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hi tehre, everything seems to work - electronically- and mechanically wise. However, no drying seems to take place and no water is extrapolated. I've cleaned the filter, airducts and the...
Rost; I will take a WAG at it. Either your thermostat is not telling the heater element to turn on or the heater element is broken. The heating element is the more likely and can be tested with an ohm meter to make sure.
Jun 19, 2011 | Bosch Dryers
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hotpoint Dishwashers
Hotpoint WD440 creases clothes badly & takes ages to dry
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Dec 11, 2009 | Hotpoint Ariston WD440G Front Load...
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WD640 Front Load...
No heat on drying cycle
If there is no heath at all , then the heating element must be checked for continuity.
If the element is fine, check the thermostat and the connection to the control board.
Feb 18, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Jan 19, 2008 | Dryers
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Dryers Logo
121 people viewed this question
Top Dryers Experts
