Question about Peg Perego 12 Volt Rechargeable Battery
CANT LOCATE CORRECT CHARGER
I NEED THE CORRECT CHARGING UNIT FOR A PEG PERGEGO RIDE ON MOTORCYCLE(DESERT TENERE)6 VOLT 12AH BATTERY MODEL NUMBER NP12-6P COULD YOU HELP PLEASE.
  • 60 Answers
For those batteries, you need the proper charger. Call peg perego directly, you will need the standard 12v charger. You can also find them at a variety of places online.
Posted on Mar 11, 2009
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Posted on Dec 13, 2008
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
My sons desert tenere won't go faster than 2.5 mph even though the specs say it can go 5mph.
you have to remove the screw for the high speed lockout, i think its under the gas cap
Jan 06, 2013 | Peg Perego Desert Tenere Ride On Vehicle
How long to charge a peg-perego 12ah battery
until the green light on the charger comes on, or 1 hour for each amp hour that the battery is, so for a 12ah battery you should charge it 12 hours
Oct 31, 2010 | Peg Perego 12 Volt Rechargeable Battery
New battery
A lower capacity battery (12v 8Ah) can/should preferrably be replaced by a better capacity (12v 12Ah), and usually more expensive, quality battery of the same voltage with higher amperage rating: it will in general take longer to charge but will also last longer in usage.
Please make sure that you fully charge and discharge your new battery pack a few times to 'condition' it.
Hope it helps and have fun!
Aug 01, 2010 | Peg Perego 12 Volt Rechargeable Battery
How long do you charge a pegperego 12 volt battery
it depends on what the ah is of the battery, usually one hour for every ah that the battery is, so if its 12ah battery then charge it for 12 hours
Jun 06, 2010 | Peg Perego 12 Volt Rechargeable Battery
Battery dies after a few minutes
Is this a toy? Is this equipped with deep cell batteries? Checked the water? Check the voltage of each battery in the pack ... should be 6 volts each ... charger putting out? Check while charging ... should be 25+ volts (make sure you measure DC.
If you have a battery that is particularly low ... it will have to be charged independently ... If this is the case, with a 6 volt charger - charge that battery. If you have two batteries that measure low ... you can charge with a 12 volt battery. You will not have to disconnect anaything to do this ... just watch what you are doing ... do not use the unit charger AND the 6 or 12 volt charger at the same time.
May 02, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Cant find the charger for my peg perego battery
I would use the specific peg perego charger. I had a neighbor who used a different one and he ruined his battery.
You can purchase them at this website I found http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
Hope this helps
Dec 02, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg perego 12 volt battery
Although what the previous post is correct, if the battery is new, and if you have the peg perego charger, you need to charge it 36 hrs the first time. After that, you can charge overnight. The peg perego charger has a small light on the front.When you plug the battery in the plugged up charger, it will show amber. When battery is charged it will show green. Don't leave it plugged up, after the first charge, longer than 24 hours.
Oct 14, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego 12 Volt Rechargeable Battery Logo
364 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
