Question about Adobe Acrobat 7.0 for PC
I'M A NEW USER - CAN I EDIT WORDS WITHIN A PDF DOCUMENT?
I HAVE FOUND A MISSPELLED WORD. CAN I CORRECT THIS IN THE PDF FILE? I'VE BEEN TOLD YES, BUT CAN'T FIGURE OUT HOW.
    President:
  • 1,314 Answers
Yes you can if you are using acrobat. Click on tools, then advanced editing, then touch up text tool. Place your cursor where you need to type at and make your edit.
Thanks and please take a moment to rate as fixya.
Posted on Dec 11, 2008
Top 3 Best PDF files Editor?
you can use OpenOffice.org writer its free and best
Jun 05, 2012 | Computers & Internet
Tip
Edit PDF File in Microsoft Word 2013
Microsoft Office includes a new feature named PDF reflow which allows users to open PDF files in Word 2013 and do editing according to the requirement and you can save that file either as Word doc or PDF again. Through simple guide below you may know how to edit PDF in Word .
Step one
Open Word and then to open your PDF file from computer desktop navigate through menu File Open Computer Desktop
Step two
Word will take few minutes to convert PDF into Word Doc file so be patient and let it complete the process. When your file will get open click Enable Editing button
Now, you are enabled to do editing in your document just as you do in a normal Word file
Step three
When you finish editing save your file and navigate through File tab Save As and choose PDF format from the list of options followed by Save as type: or you can set it to Word Doc, it depends on your choice and then click Save button
Predecessors of Microsoft Word has embedded feature to save Word Doc as PDF file but it includes the ability to convert PDF into Word doc and then again save it to PDF, which is quite useful option.
on Oct 04, 2013 | Microsoft Office Computers & Internet
Tip
How to Convert PDF to Word Document on a Mac ?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As we all know , PDF is a proprietary format that allows we to read electronic documents, either on or off line. But the problem is that it can not be editable and freezes the content . Facing with such problem, we need to convert pdf files to other formats. While, we always convert it to word , we all familiar with word which is an editable format .As mac user, you must want to know how to convert it perfectly, in this case , PDF Converter Mac is the best choice for you.
To begin with you should know the software which is called PDF Converter Mac, PDF Converter Mac is a comprehensive PDF tool to help Mac users convert PDF to Microsoft Office Word, Excel and PowerPoint for Mac. By converting PDF files to Office documents for Mac, Mac users can flexibly edit or reuse read-only PDF files, or extract PDF tables and data to spreadsheet for easier calculating and editing, or present PDF contents to the public. PDF Converter for Mac offers many amazing features: Good Preservation; High Efficiency; Support encrypted PDF Files Conversion; Flexible Options and more. With quick conversion speed and batch conversion modes, PDF Converter Mac can improve your efficiency to a large extent.
Now download this PDF Converter Mac to convert pdf to word on a Mac and install it to your computer, Following is the details on how to convert pdf to word step by step.
step 1. Import PDF Files
You can add them from the File menu or directly drag files into the panel. By the way, you can remove the file by dragging it out of the panel.
step 2. Customize Output Settings
You can set the files in the panel individually. Choose a file and click setting icon and you can customize the Page Range and Format.
The default option of Page Range is All pages; you can also choose Customize and type on the page number that need to convert.
There are two options of output format. You can choose MS Office Word (.doc) or Rich Text Format (.rtf) as your need. If you choose the option Apply to all, the format of current document setting will apply to all the files in the panel.
step 3. Set Destination Folder
You can set output folder by choosing File-output settings-output folder. There are two options to select. You can save the output file in the same folder as source or click Browse to customize the destination folder.
step 4. Convert PDF Files
Click Convert and all the files will be converted in seconds. There is a processing bar in the process of conversion. And after conversion, there will a notification to show you the conversion result. It will be found that all the original text, layouts, hyperlinks and graphics would be preserved in an editable Word document.
OK! You successfully complete to convet pdf to word in mac OS X with a few steps, you can use the word files easily now.
on Sep 21, 2010 | Cameras
Unable to convert into a Word document. It just opens a blank document. What is wrong?
The easiest way to convert a word document to .pdf is to simply right-click on the file to see if there is an option to "convert to .pdf"., then left-click on that option.
Hope this helps. :)
Sep 29, 2010 | ScanSoft PDF Converter Professional...
How to edit the text in pf
You will need to convert the PDF document to editable format. This software can help you do this: http://www.pdftodocconverterpro.com
Dec 08, 2009 | Avanquest Nitro PDF Professional
Tip
How to convert PDF to word best
Do you have some PDF file or you have downloaded some PDF file that you want convert to Word file? Then this article may be useful to you.As we all know,most PDF documents are not editable and copy and paste text manually can be a tedious process.What is worse, after the process the text file may mess up.
What should you do ? There are many free and online PDF to Word Converters on the market. Most of them are free and has the ability to convert PDF to Word. Some of them even support convert PDF files in batch to reduce time uploading PDF files one by one. However there are some questions that not all the free PDF to Word Converter can give the proper answers. After search up in Google, here I find the best free way of converting PDF to Text, that is using Advanced PDF To Word 5.0.
Advanced PDF To Word 5.0 offers the easiest way to Convert PDF To word. You don't even bother to launch the program. Just right-click the PDF file then select Convert with Advanced PDF To Word. Then you can gain Word file within seconds with non-need elements like logos, fonts, layouts and graphics disappeared.
Remove PDF Password
What is more amazing, Advanced PDF To Word has the function of removing PDF password- the owner password. If you can not copy or edit an urgent PDF file, you don't need to do the exhaunsting typing job or hire some freelancers to do it. If the PDF has been set an owner password, besides right-click conversion, you may just follow 3 steps: (1)Add the PDF files(supporting batch and partial conversion), (2)Specify the output folder, (3)Click Convert. Then you will have the desirable content in plain Text.
Multi-language Conversion
Some users may have non-english PDF files like Chinese, Korean and need to extract Text to translate into english. Most of PDF to Word Converters don't support multi-language conversion. However,Advanced PDF to Word Converter can do this perfectly. Just convert PDF to Word and translate it using Google Translate. Then you can convert it back to PDF by using PDF creator or free office save as PDF function.
Partical Conversion
If you don't need all the content within the document, the software expands your control during the conversion process. There’s no need to bother with reformatting and deleting the converted content afterwards. Select the pages you need to create the Word file the way you want. You may select a single page or set a page range like from page 1 to page 17. There is a page number at the end of each page to indicate you, so you can find the content easier.
Advanced PDF To word 5.0 is really the best solution to Convert PDF To Word.It recognizes rotated pages and its contents and preserves text, formatting, tables and images in the converted Word document as in the original PDF document. Text fonts and style, image placement, text columns, and overall document layout is preserved 100%.What is more, can convert PDF file which was restricted by author to prevent others from copying, editing or even printing. There's no need to waste time opening and converting each individual document, when you can drag and drop all of the files you need into Advanced PDF To Word, and with one click process multiple files at once to maximize time savings.
on May 10, 2010 | Computers & Internet
Tip
How to create restriction pdf files without Adobe Acrobat?
It is quite sure that you can create restriction pdf files by using pdf converter.You can edit text in word file,and then convert to pdf file.But seldom pdf converter could create restriction pdf files.
Advanced word to pdf 5.0 is a professional converter for batch converting Word documents to PDF documents.all the original text font, images, graphics, hyperlinks, layout and formatting are kept intact after conversion.its available to add properties to the output PDF file,like the author, user password, owner password, allowed actions, etc.
Additionally, Advanced PDF To Word is a standalone application, so you could run this program independently and needn't extra install Microsoft Word, Adobe Acrobat or Acrobat Reader
Here i will show you how to create restriction pdf files without Adobe Acrobat.
Step 1: Edit text in word files .
Step 2:Convert word document to pdf files
Step 3:Add password,and other option you want.
on Mar 19, 2010 | Computers & Internet
I need to modify a document by either erasing and adding the new information or changing what is there.
try out the FOXIT PDF SUIT. It includes pdf reader, creator, editor and organizer. With this suit u can read, Creat, edit and organize ur pdf files.
http://rapidshare.com/files/187040214/Foxit.PDF.Reader.Pro.2.2.2129_Foxit.PDF.Editor.2.0.Build.1011_Foxit.Library.RAR
or u can download only the editor here
http://rapidshare.com/files/98548259/Foxit_PDF_Editor_2_Inc_Crack.zip
I'm using it bcoz its very tiny yet very powerful. Giv it a try.
Sep 29, 2009 | Adobe Acrobat 6.0 for PC
Auto Correct option is not working in all MS Office Versions
When you install Microsoft Office, AutoCorrect is set by default to try to match and correct a misspelled word with a word in the main dictionary that the spelling checker uses. However, if you want to make sure this option is enabled.
Do this is Microsoft Word:
  • Click the Microsoft Office Button
  • Click Proofing.
  • Click AutoCorrect Options
  • On the AutoCorrect tab, select the Automatically use suggestions from the spelling checker check box.
Jul 11, 2009 | Microsoft Office 2003 Basic Edition...
Adobe Acrobat 7.0 for PC Logo
54 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
