Question about ViewSonic Optiquest Q7b Flat panel TFT 17" Monitor
View sonic Optiquest Q7B-3 comes on for a second then black
The monitor comes on for a second then goes black. I was told to replace the flourescent starter. I wanted to get another opinion before I proceeded.
  • Anonymous Apr 11, 2009
    My monitor Optiquest Q7B-3 is coming on for a second and go off. The green light is blincking. Can you tell me what is wrong? What parts I have to replaced? Thank you.
Dantheman009,
Don't know if this will fix your problem, but my monitor did the same thing. If you look on the bottom of the power supply board, you will find Q305 and Q306. They are probably both shorted. I replaced both transistors and the capacitor C305 on the top of the same board. The capacitor was open. After I replaced the parts it is working again. Look with a magnifying glass and make sure there are no bad solder joints. The only place I could find the transistors were at
www.bluestar-online.com. Make sure you order the 2SC5706. It is an exact replacement.
lotto-50
Posted on Dec 24, 2008
View sonic computer screen was dropped and now when you turn it on the picture comes on and then it emits a high pitched sound and turns off. any suggestions?
Sounds like you may have broke at least one of the lamps . The high pitch sound you are hearing is the high voltage that goes to it .
Feb 05, 2011 | ViewSonic OptiQuest Monitor
ViewSonic Optiquest Q7b 17" LCD Monitor has a fuzzy picture
LCD monitor needs to be fed with native resolution from the PC video out, this monitor native resolution is 1280x1024 @60Hz, try that setting to see if it helps before opening up the monitor to look for failed components.
Mar 29, 2010 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Optiquest monitor screen turned bright pink. How to solve this issue?
First check your cord from the computer to the monitor to make sure the connections are clean and good on the blue vga cord. Plugging it in and out a few times will help clean the pins and holes.
If that is ok: then it may be bulbs.
Pink means that you have bad bulbs inside the screen. sometimes the pink goes away when the bulbs warm up. eventually it won't stay on.
There is a slight chance the power board is also getting weak. You would have to open it up to tell this.
Once partially opened, Disconnect the wide set of wire that goes from the back of the screen to the monitors main video board and then try to turn it on, If it is still bulbs they will really show up with this setup.
If you send me a picture of the power board to bammbamm@ptd.net, I may be able to tell if the board has issues by looking at the picture of it.
Fran
Dec 13, 2009 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
I have a viewsonic optiquest monitor Q20WB and buttons not workin
Sounds like that monitor has reached the end of the road. I would recommend purchasing another monitor, other than view sonic. Purchase a Dell..they are great!
May 13, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Optiquest q20wb Screen goes blank after powering off
I had the exact same problem. The screen went black and the green light flashed. I went ahead and took the monitor apart (scary) and took a look at the power supply circuitry. I saw 6 suspicious electrolytic caps on the board. Three 470uF 25V 105 degree C caps, two 1000uF 10V 105 degree C caps, and one 470uF 10V 105 degree cap. They all appeared to be slightly bulging and one even had a small hole in the top. I decided to replace all of them. The parts cost a little more than 5 bucks. I couldn't find a 470uF 10V cap at my local store so I bought a 16 V version instead, which is fine. Anyway, after replacing all 6 caps, the monitor works as good as new.
Mar 02, 2009 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Optiquest Q7B-3 Model Vs11147
Actually that model has an integrated inverter with the power supply. Should be part # xlm1700390004 they cost around 25 bux and are fairly easy to replace.
If you are handy with soldering you could check the three 470 uf caps on the board they are tank caps and when they go they do what you are describing. Open the monitor and look at the three black capacitors if the top is bulged they are bad. If you have a capacitance meter check the capacitance it will most likly be well below 470 uf the caps are cheap like 39 cents if you do go this route use 30v not 25v caps to be on the safe side.
Word of warning switching power supplies can kill you quickly never work on it live and let it discharge at least an hour before working on it.
Dec 11, 2008 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Computers & Internet Logo
728 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
