Question about Lands Phones
My phone (27831) will not ring when call is incoming. I set ringer and default but default keeps going to no. What am I doing wrong?
  • 75 Answers
May be the speaker might not be working replace it r reinstall software
Posted on Dec 11, 2008
Will not ring on incoming calls
On the top left edge of the iPhone there is a small lever. It is just above the volume up and down controls. Flick it back towards the screen of the phone. This is the 'ringer off' switch. You will get a display on the screen telling you whether you are ringer on, or ringer off.
Other possibility is that the Settings/Do not Disturb setting is activated.
Nov 10, 2015 | Apple iPhone4 4G iPhone 4
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Lands Phones
No sound on incomming calls
Hi,why it does not ring out is because,the ringer is damaged..and it needs replacement. Before you replace it,you can clean up where the ringer is,there might be dirt stopping it to work.But you have to unscrew the phone to see where the ringer is.
Please if you have no knowledge about the phone,you can contact a skillful personnel for assistance.
Before that you can trythe below step,might just be a setting problem.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Have a nice day.
Sep 19, 2011 | Nokia C3 Cell Phone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
No sound in ringer
First You Go to Phone setting in Sound & Ringing Setting and check the Phone Ringing Setting if Ringing Setting alrdy OK
But No Ringing So
Secnd Option:
Your phone Ringer Default SO Please change Ringer
and Ringing Sound Problem will Solved
Aug 27, 2010 | Sony Ericsson Cell Phones
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
INNOVAGE 1604007
Press SET. Press UP to select Set 8 Speech. Press Set again to confirm. Screen will show default setting SPEECH ON. press Up or DOWN to select ON/OFF. Press SET to confirm newetting
Oct 23, 2008 | Innovage 1604007 Corded Phone
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
