Question about Oreck Cordless Speed JP8100CA Iron
MY IRON DONT STEAM
I DONT KNOW WHY MY IRON DONT MAKE ANY MORE STEAM
  • Oreck Master
  • 43,501 Answers
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
My Tefal pro iron sometimes makes noise and dont steam any more?
get rid of the calcium,and use distilled water for steam,not tap water
Jun 20, 2015 | Tefal Pro Express GV 8120 Iron
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
Logik steam generator iron no steam
Service the steam and spray mechanism:
Unplug the iron.
Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
God bless you
Jan 24, 2013 | Irons
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Rowenta iron
Dropping any iron is the kiss of death... dont use it again, especially on the steam setting.. you could electrocute yourself..
Dispose of it safely and get a new one. You wont make that mistake again in a hurry... I didnt!
:o)
Aug 03, 2008 | Rowenta DZ1700 Iron
Tefal Aquaspeed 160 Steam Iron
I have been able to rest the iron by simply moving the iron back and forth. try it.
Mar 25, 2008 | Irons
How to use steam iron
Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
Feb 23, 2008 | Micro Pro 7599 Iron
Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Dec 23, 2007 | Irons
Oreck Cordless Speed JP8100CA Iron Logo
137 people viewed this question
Top Oreck Irons Experts
Kevin Getz
Kevin Getz
Are you an Oreck Iron Expert? Answer questions, earn points and help others
