Question about Toshiba 32D46 32" TV
Toshiba 32D46 - Will Not Turn On - White Lines Near Top of screen
Hello all,
I bought my 32 inch Toshiba at BestBuy around 2 years ago or a bit less. It was working perfectly for most of that time until about 2 months these annoying white lines formed near the top of the screen. They sort of look like interference or something and for awhile that is what I thought was going on.
I dealt with the white lines by changing the viewing mode to the widescreen mode which is not always great but at least it got rid of the white lines.
About a month ago I came home and tried to turn on the TV and could not. I tried everything, changing batteries with the remote, changing where I had it plugged in etc with no luck. A week later I just thought I would try and turn it on for the hell of it and what do you know? It turned on! I still had those dammed white lines but the TV turned on and off and back on with no problems...
A week ago Bam! The same problem and I cannot turn the TV back on. I cannot believe a TV would last for less than 2 years in a safe enviroment. It is not like I have the TV outside or anything. I have always taken good care of the TV and there has never been any problems at all with humididy or moisture or over heating.
I am reading hjere that many people are having these same problems with this model and I would like to suggest that we get together and contact Toshibe. I believe this should be recalled because there is something faulty with either parts or design.
Thanks
WebDevoMan
  • 3 more comments
  • Anonymous Jan 02, 2009
    I'm having same trouble
  • Anonymous Feb 14, 2009
    i have the same problem
  • our4family Feb 15, 2009
    i have the same problem, yesterday it just stopped working
  • talamar1 Feb 24, 2009
    White lines at the top of the screen after 2 years.
  • Anonymous May 12, 2009
    same problem here - try turning it on in a day or two and and it turns on
I have the same problem with the same TV from Tosiba. I think Tosiba know about it but did nothing to repair it but sold millions of the same TV and Made good money. I think we all should soin togather and file a class action lawsuts against the company. They must fix the TV or pay our money back plus pay for our pain and suffering. There are many lawfirm will take this case and get paid from proceed. Ray@raykraan.us
Posted on Jun 14, 2009
Schatzie:
I have been having the same problem as well any suggestions
Posted on Feb 26, 2010
Toshiba 32D46 - Need to know weight in order to determine whether tv stand will support it safely.
Hello
Your Toshiba 32D46 model TVs weight and diamensons are
Width: 29-9/16 in. (751 mm)
Height: 25-15/16 in. (658.5 mm)
Depth: 21-3/4 in. (552 mm)
114.7 lbs. (52.0 kg)
OK
Jan 02, 2011 | Toshiba 32D46 32" TV
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
HORAZONTAL TRACE OVERLAP AT TOP OF SCREEN. MY TOSHIBA 32D46 TV HAS DEVELOPED WHAT LOOKS LIKE A FOLD OVER OF THE TRACE AT THE TOP OF THE SCREEN, ABOUT 2 INCHES. CAN THIS BE ADJUSTED OUT BY ADJUSTING THE...
Usually that is caused by a part failure. The vertical deflection ckt is most likely the roblem. Sometimes it's just a cap usually a 100mf right next to the vertical ic chip. Or it can be the ic itself. Unfortunately you can't adjust it out.
Feb 23, 2010 | Toshiba 32D46 32" TV
Where is the Vertical I.C on a Toshiba 32D46? PICTURE PROVIDED!
on the back of the tube,is a yoke with two drive coils,on is vertical drive,and the other is horizontal.follow the plug to the pc board where it is labelled vertical in white writing.there is a chip with a number like ta7267. beside it are some capacitors and there is a 4.7 50 volt capacitor beside the heat sink.the heat sink heat dries them out
Jun 12, 2009 | Toshiba 32D46 32" TV
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
as i've read you statement your tv need to check parts by parts, the one you mention upside trace vertical line, that part control on vertical ckt faulty parts nearly to faded filter capacitor you can directly replace all capacitor of vertical section. the one you adjust is that the playback transformer the upper portion is focus and the lower portion is screen voltage controlling screen voltage supply to crt g2 pin. if you turn this high that resulting hazing sound come from 2nd anode cup.
Mar 29, 2009 | Toshiba 32D46 32" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Toshiba 32D46 32" TV Logo
621 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
