Question about ViewSonic Optiquest Q7b Flat panel TFT 17" Monitor
Optiquest Q7B-3 Model Vs11147
The Lcd come on, stay on for 3-4 sec then gose blank I have same Problem did anyone try this. I was told to replace the flourescent starter.
  • 1 more comment
  • dansengine Jan 20, 2009
    I have the same problem except my goes blank after 1 hour after turning the monitor off and on it works for about 2-3 minutes and does the same thing.
  • j_scottn Mar 25, 2009
    I have the same Monitor and it does not power up at all. Should I try replacing the power supply?
  • Cedric Hamilton May 11, 2010
    In response to Solution 1. I replaced the capacitors on the Power supply. I actually replaced four of them with a slightly bigger capacitor and it still did the same thing. I believe one of the transformers or Transistors or something else is also messed up. I think it would be worth replacing the board.
Actually that model has an integrated inverter with the power supply. Should be part # xlm1700390004 they cost around 25 bux and are fairly easy to replace.
If you are handy with soldering you could check the three 470 uf caps on the board they are tank caps and when they go they do what you are describing. Open the monitor and look at the three black capacitors if the top is bulged they are bad. If you have a capacitance meter check the capacitance it will most likly be well below 470 uf the caps are cheap like 39 cents if you do go this route use 30v not 25v caps to be on the safe side.
Word of warning switching power supplies can kill you quickly never work on it live and let it discharge at least an hour before working on it.
Posted on Jan 06, 2009
    Champion:
  • 293 Answers
Hi...there,
Well... not exactly, what you need is a new backlight inverter. The one you got it busted...
Posted on Dec 12, 2008
The picture wont stay on the screen, sound will work, but i cant see it (the picture), if i turn it off for a few minutes and then turn it back on it works for a little while, but eventually it will go...
This is a backlight issue. LCD televisions require a light to be on permanently behind the visible LCD. This is usually provided by tubes called CCFL or cold cathode flourescent lamp. There will be multiple lamps arranged around the edges of the screen. It sounds most likely to be a due to one or more bad capacitors, which can be easily replaced by anyone experienced with electronics.
It could be a faulty inverter transformer but this usually causes the backlight to switch off within seconds of switching on due to protection circuitry in the inverter controller circuit. If the inverter circuit is faulty then the inverter board can be replaced.
If you are not competent with electronics then take your TV to be repaired by a qualified Tv repair engineer.
Feb 12, 2011 | Vizio Televison & Video
Insignia 37 in lcd, trun on light gose blue
It is the main board failure, because Insignia TV has no error blink design.
May 10, 2010 | Televison & Video
How to open (remove back) Omnitech Vw19B LCD Monitor
You are right about the problem on the flourescent, but the issue is caused by the mosfet transistors. You need to use a flat screwdriver to pry the back of the display until you get this open. Start from the bottom side because some damage will be left on the plastic.
Apr 15, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Philips 150S screen turns on for 1 sec. and then gose dark???
nyounger4242, Very common problem!! learn to do flashlight test to evaluate "switch-mode-power-supply" status. Read my FIXYA profile to find out all you need to know about Black, or Black and Blank lcd screen fixes and the options you have. Your monitor NO DIFFERENT than any other CCFL Back-lit LCD monitor in it's basic design and operation!! Good luck with repair. Use warranty if possible. Read, Read, Read, before you do anything!!!! 12fixlouie
Feb 04, 2010 | Philips 150S4FB 15" LCD Monitor
1999 nissan frontier truck won't start it just clicks
try to turn the headlight on and start if the light gose off at the same time you need to replace the battery , but if its stay on and no start change the starter
Mar 16, 2009 | 1999 Nissan Frontier
My microtek 517m lcd monitor it keeps going blank
the monitor its self has no problem but try installing the drivers again
Feb 06, 2009 | Black Box Computers & Internet
hey momcowles3 wondering if you could do me a favor. i've been looking for the microtek 517m drivers online for a couple days now and there is nothing. I was wondering if you could give me a copy of the drivers. i can't find my installation cd either. thanks
Jul 30, 2008 | ViewSonic VP181s 18.1" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Monitor Goes Blank after 30 mins....
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Dec 12, 2006 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
1,519 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
