Question about HP OfficeJet 6110 All-In-One InkJet Printer
Right cartridge is showing error.It says not in correct place
  • mcooner953 Dec 11, 2008
    it is a hp 6110
  • 107 Answers
What model is your printer? You may actually have a hole in the board/ribbon behind where the ink goes in. This is caused by a spring that breaks loose and punctures that ribbon. You should be able to see it just by looking in the unit. Even if there is a dent it will make it defective and nothing you can fix. Only exchange from HP.
Posted on Dec 11, 2008
  • Joe Lepe Dec 11, 2008
    Yes, this is one of the model that are known for this issue. Check the ribbon behind where the ink cartridge goes and you should see a whole/dent in the ribbon.
Rec error code 6000 on pixma mg5420. Just purchased yesterday
It may be superficial for a question but did you remove the plastic film on the cartridge ?
Feb 02, 2015 | Office Equipment & Supplies
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem:
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
I have a Lexmark X4200 all-in one with an error designation of error 1200 What do I do to get rid of this error
The error means that the cartridge carrier can not move freely. This can happen if the cartridges are not correctly seated, the encoder strip is out of place or there is a foreign object blocking the path.
First check that the cartridges are properly seated and locked into place. If that doesn't help, then remove the cartridges. Move the cartridge carrier belt (black) to the left. Push the encoder strip down and then up to get it into the slot on the back of the carrier. If needed move it forward and then back to slide into place. Reinsert the cartridges and move the carrier back to the right.
Next gently move the cartridge carrier belt left and right listening for any rattling or other sounds of a foreign object. Remove anything that doesn't belong in the unit.
If none of the steps help, contact Lexmark. has pictures.
I hope this helps.
Apr 25, 2010 | Lexmark X4270 All-In-One InkJet Printer
Laser printer shows light in error led ,no printing what is the reason
Error means the printer can see a paper in the paper tray side, it thinks there is a paper in the exit side, or there is paper near the toner cartidge. tr removing and reinstalling the cartridge. Look for paper, check the printer cartridge is properly installed and the paper tray is in the right place and loaded right. The owner's manual shows how to clear paper jams.
After this, you need the help of a printer repair shop.
Mar 21, 2010 | Konica Minolta PagePro 1300W Printer
Epson RX425 Ink Cartridge problem
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Jan 02, 2010 | Epson Stylus RX425 Multifunction...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
"Wrong cartridge" error when in fact it is the right cartridge
On this machine it means the printhead is bad. QY6-0049-000 around $40.00
Jul 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Query msge: Insert black or photoprint cartridge in right stall
REMOVE both cartriges then insert it again correctly in proper places
May 06, 2009 | HP Officejet 7210 All-In-One InkJet...
My message window shows error 1200. What does this mean? I cannot find a solution in my trouble shooting guide
Try this first step to correct it
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay. if the error still persists Could be a timing belt issue, gearing or a jam, etc.
Typically, Dells are Lexmarks...
If you're comfortable with a wrench, have a look here: .hope this solves your problem .appreciate by rating this as fixyaa
Sep 30, 2008 | Office Equipment & Supplies
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
