SAMTRON COMPUTER BACK TO SETTINGS FACTORY
  • Smoking_gnu
    Smoking_gnu May 11, 2010
    You want to wipe the system?
    do you have restore disks?
    Novelist:
    Champion:
  • 233 Answers
Go into BIOS and reset to default.
Posted on Dec 27, 2008
I need display of 56v samtron monitor
Did you check the adjustment setting on the brightness and contrast?
These two setting can be moved and stop the CRT from displaying,
Please move these two setting to MAX and see is there any image on the display.
Jan 31, 2011 | SAMTRON 55V 15" CRT Monitor
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
The monitor`s display adjustment panel is showin "CONTROL LOCKED" I cannot change any settings(like brightness,v-size,etc)... wat do i need to do?? plz suggest
Well for Sumsung with a 3% failure rate is unusual, I would try and reset to factory settings if that does not work, They have a pretty good waranty on them seeing they never break down. average is 3yr.
Jul 14, 2010 | SAMTRON 55V 15" CRT Monitor
I am trying to clone my lapptop image with a samtron 73.v and the samtron seems dead :-( It says Test Good but does not work
Most laptops have three video-settings:
* output only to internal screen
* output only to external monitor
* output to both internal and external
Select the appropriate video-setting.
Set your laptop's screen-resolution to 800-by-600 by 60Hz -- a resolution that should be compatible with any 15" Samtron monitor.
Dec 26, 2009 | SAMTRON 55V 15" CRT Monitor
Minitor is shrinked on both side horizontally. The settings are all ok and resolution is perfect. Seem some problem with CRT or something like H/W. Any help on this???
Hi...there,
Open your on-screen display on your monitor, find & press auto adjust. If that doesn't work go to factory reset menu and pressed to reset to original settings.Then reboot your pc.
Jan 28, 2009 | SAMTRON 55V 15" CRT Monitor
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
Screen settings problem
OSD = On Screen Display. Once loaded it is normal for the OSD to stay on your screen untill it times out or you Exit it.
Nov 24, 2007 | Samtron MONO TTL 13 Monitor
Samtron 98BDF
Since your monitor is recieving data I would look at your computer hardware for the solution. Did you recently add a program to your computer? Or change a BIOS setting ? Did you have problems with your hard drive?
Sep 18, 2007 | Samtron 96BDF 19" CRT Monitor
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
