Question about Philips 26MD255V 26 in. LCD TV/DVD Combo
No red light on TV so doesn't turn on, yet cable box lit
The red light was on but when I pressed the power button on the remote, the TV did not turn on and now neither a red light or green light is lit on TV. Cable box is on and power lines are fine. Could the Adapter be the problem or what other solution?
    Novelist:
  • 152 Answers
Hello, check you power cable make sure it is properly attached.
test your power outlet, also try using another outlet if possible,
try reseting your fuse box switches.
if it is not your outlets then you may have a fualty power supply, if theres no red light means theres no power reaching the internal circuts it may be numerous reason for this or even a simple blown fuse on the powersupply, but basically no red light means no power.
unfortunatly one or more of your internal board may need to be serviced or even replaced this is not something you want to do your self the voltages inside of these systems are very dangerous and you need model specific service manual,schematic, and electronic circut test equipment. if your electronically inclined you can check to see if your fuses are blown but i dont recomend it unless you have some basic safety and electronics training.
besides this most of these tv's need to have there voltages tested and adjusted after board replacements.
suggestion: search for a qualified service center who can give you a estimate for repair, search around some companies offer free estimates
and will even come out to your home and check and repair your tv on the spot.
if it is under warantee you may be able to get a replacement or repair without charge. if not then get your estimate find out whats wrong and find out what service center offers the best price for the service or repair.
hope this helps
good luck and happy holidays
Posted on Dec 11, 2008
Sharper Image jumbo remote will not accept codes
Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
Dec 31, 2009 | Innovage Jumbo Remote Control
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Innovage Jumbo Universal Remote and Comcast Cable
I do not see Comcast cable codes in the manual, so I recommend using the auto-search function for both CABLE and SAT to find one that works for you.
I hope that helps.
Nov 11, 2009 | Innovage Jumbo Remote Control
Cannot get our jumbo remote to operate our satellite receiver which is a Direct TV. Tried all 17 codes.
Unfortunately, this model does not have a learning function, so if it doesn't know the code for a newer product, it cannot be taught. I recommend trying the auto-search function for both CABLE and SAT to see if it can control your Direct TV box.
I hope that helps.
Nov 10, 2009 | Innovage Jumbo Remote Control
I need codes to program direct tv satelite
Direct TV codes are not provided with the Innovage Jumbo Remote, but it is possible the codes for another box will work. I recommend using the auto-search function for both CABLE and SAT.
I hope that helps.
Unable to find code for time warner cable on the innovage Jumbo universal remote
I recommend using the code-search function of the Innovage Jumbo Remote for both CABLE and SAT to try and find the one that works with your Time-Warner cable box.
I hope that helps.
Nov 03, 2009 | Innovage Jumbo Remote Control
Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
  1. Turn on your TV.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
I hope that helps.
Jul 18, 2009 | Innovage Jumbo Remote Control
My dad has an insignia tv with AT&T u-verse cable. How do we get the remote to work?
Your best bet is to use the auto-search function for both the TV and the cable box.
  1. Turn on your TV.
To program for the cable box, I recommend search both the CABLE and the SAT code lists using the steps above, but substituting the CABLE or SAT button for the TV button.
I hope that helps.
Jul 13, 2009 | Innovage Jumbo Remote Control
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Philips 26MD255V 26 in. LCD TV/DVD Combo Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
