Question about Vivitar PZ 3140 DB 35mm Point and Shoot Camera
Something in between the Lenses
There seems to be something inbetween the front lenses in the camera. Is there anyway to clean it out myself? Or should I just take it to get fixed? Or should I just get another camera?
0 characters
1 Points
I have a Rollei 2.8 projector lens that is loose inside. how do you take it apart to see if it can be repaired?
If you do't have the knowledge or the equipment to align lenses, I don't think it is wise to try to "fix" any lens.
Nov 02, 2013 | Point and Shoot Film Cameras
Where can I buy a new battery door for a gold oly stylus 35mm f2.8 fixed lens camer
There are several models of Olympus cameras with 35mm f/2.8 fixed lenses. There is a list of available parts, including battery covers, here.
Nov 24, 2011 | Olympus Infinity Stylus 35mm Point and...
Camera shows flashing H in rear screen and won't wind on film
Unfortunately on your model the flashing H means there's an electrical fault which needs repair.
In practice, it's an old obsolete model and few spare parts will be available. Any kind of professional repair will cost far more than the camera is worth. But as almost all 35mm compacts are now virtually worthless it means that you can get fantastic models for free or very cheap. All of mine have come for free via FreeCycle, Freegle, and by just asking people I know as most have unused and unwanted cameras lying around. Even the superb and very under-rated Canon Sureshot Classic 120 which has one of the sharpest lenses ever put onto a 35mm compact can be had for zilch as the batteries cost more than the camera is worth (new batteries: about £10).
Sorry this is not the answer you hoped for, but I hope that it enables you to fix the problem in a different way at almost no cost.
Mar 01, 2011 | Canon Sure Shot Z155 Caption 35mm Point...
I got my pentax k2 camera lens cleaned for it has got fungus. Now the lens has been completely ruined and I am not being able to use the camera at all. Could anybody tell me where can I get lens for the...
Cleaning a lense for fungus is an iffy if not impossible procedure most of the time as the fungus attacks the material of the lense itself and parts of the lense have to be removed to remove the fungus.
But, the good news is any dealer of new or used equipment will have K-mount lenses. You can find both new and used lenses from B&H, KEH, Adorama, Calumet, and others - though those are some of the most reputable online/mail-order dealers of used and new equipment. You can find almost any kind of lense you'd desire.
Oct 01, 2010 | Pentax K2 Film Camera
I need instructions for minolta freedom zoom 70 exI want to know what macro does.
Hi. As a pro photographer, I can tell you what 'macro' does on all cameras or lenses. 'Macro' focusing is for focusing on close objects, say an inch or two from the lens to a couple of feet. It is for closeup shots, say ants, or a fly, or someone's eye, raindrops on glass, etc. Try it out sitting on a patterned countertop or table or tablecloth to give you an idea, focusing far away and up close.
As far as the manual, there doesn't seem to be anything on the official site unfortunately. Good luck and have fun.
Apr 14, 2009 | Minolta Freedom Zoom 70 35mm Point and...
Minolta Freedom Zoom 90 Camera will not flash
Common problem.
Flash transformer needs replacement.
Mar 30, 2009 | Minolta Freedom Zoom 90 Date 35mm Point...
Contax TVS II film camera
Hello trescam,   I recommend you check out the website or look up the model at the Kyocera camera website. All T series cameras had fixed lenses.
Sep 26, 2008 | Contax TVS II 35mm Point and Shoot Camera
Error message L1 and L2
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
May 31, 2008 | Leica Minilux Zoom Date 35mm Point and...
Hope you can help!!!!
there should be a small but long narrow window on the back of the camera that should tell you if theres film in ther or not. to open the camera, flip the rewinding crank (located on the top left) and pull up until the back pops open.
Apr 09, 2007 | Kalimar K-90 35mm 35mm Point and Shoot...
Vivitar PZ 3140 DB 35mm Point and Shoot Camera Logo
16 people viewed this question
Top Vivitar Point and Shoot Film Cameras Experts
Steven Wander
Steven Wander
Are you a Vivitar Point and Shoot Film Camera Expert? Answer questions, earn points and help others
