I have a top flush cistern and the water is not shutting off when the cistern is full its spilling...
(More)
I have a top flush cistern and the water is not shutting off when the cistern is full its spilling back into the bowl - can't see where the problem is?
cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction...
(More)
cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
for black water application on 44 ft boat, level light indicator remains on low, then when full goes...
(More)
for black water application on 44 ft boat, level light indicator remains on low, then when full goes to full setting, no empty or mid reading on display panel as had been normal. System worked fine until 3 month lay up Aug-Oct..prior to lay up had system pumped out, flushed with fresh water, pumped out again and shut down. Boat is 2008 but has accumulated about 1,000 hours engine time.. traveled 9,000 + miles. Sealand product has never failed us and still works fine except holding tank monitor. I thought about removing sensor probe elements in tank but hope another answer will correct.
