I put some new parts in my pc and knocked the wires for the speakers and dont know where to recconect them to my motherboard?
  • Smoking_gnu
    Smoking_gnu May 11, 2010
    what motherboard/pc do you have?
    tell us that and we can tell you where the cables go :)
  • 69 Answers
You'll need to plug it into the Analog Output; you can see a general picture of the back of a computer here. The key is that the icon next to the Analog Output port, with concentric circles and the arrow going out, is the same on every computer, so that's what you need to look for.
Posted on Dec 11, 2008
Where and how to wire motherboard intel 775
You should be able to get the pin outs and connector specifications from the HP website for that workstation model. Go to the service manual and it will have detailed information on what you need.
May 20, 2014 | HP Workstation Xw4100 PC Desktop
My speakers dont work ,so I dont know if the speaker connector should be connected to motherboard, because it is not.
Try plugging in headphones and see if you can hear anything, if not, it's a driver or motherboard problem. Update to the latest drivers. If that fails, buy a new sound card for around 20 bucks at local BestBuy or online. If this is a desktop, check the back of the PC for a second set of input slots. They are usually color coded and marked with symbols indicating what goes where (not to insult your intelligence in any way).
Jul 27, 2011 | Computers & Internet
Case has 1 small speaker in front but dont know where to connect to motherboard. speaker have 1 black & red wire on small female plug
Input the speaker's jack to the mother board,from back side or the front panel,which is green socket.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | Intel Motherboard
I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
Jan 07, 2011 | Shuttle AN35N Motherboard
I have an emachine t3104 and upgraded the memory the wires from the front of the case became un attached now I dont know where they connect on the motherboard they are black and whitebbgreen and white and...
That model has a MSI K8MM-V (MS-7142-010) motherboard. Mostly likely you knocked some of the computer case wire connectors off the motherboard. These connectors usually include things like the case speaker, indicator for your hard drive operating, etc.
You may want to do a websearch for the manual, which will show a detailed breakdown of these wire connections and how to reinstall them.
Aug 28, 2009 | Computers & Internet
Puttin new speakers i dont know what color the stock speaker wires are
2002 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 16, 2009 | 2002 Chevrolet S-10
Simply no sound from PC
Check if you have plugged in the stereo pin to the right port on the PC.
Open sound control (in control panel) and check if the both speaker(main volume) and the wave volume sliders are not set to the lowest.
Apr 02, 2009 | Computers & Internet
Dont know where an item should go
This is an internal speaker. Find the speaker pins on the mother board. Should be somewhat close to the front panel connections.
Mar 23, 2009 | Abit NF7-S V2 Motherboard
Need to know how to wire it.
Here is a link to where you can download the manual for this motherboard: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=193&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Mar 04, 2007 | EliteGroup K7SEM Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
