Home | Standard Registar | SD650 Color Copier | My copies are too lig...
Standard Registar SD650 Color Copier
Problem for Standard Registar SD650 Color Copier
My copies are too light or too dark, what should I check for?
By Ryan - usenet poster
Same Problem
Mar 25, 2009
-   The copy machine at my mother in laws daycare has been printing very dark copies and we don't know what to do to fix it. Any help would be appreciated we don't really have the money to purchase a new one at the moment so fixing this one would be a HUGE help to us. Thank you :)-   angela_is_me
Apr 10, 2008
-   Dear Sir, I have a Lanier 6713 copier (Similar to Toshiba 1370). My problem are
(1) The copies copied had dark edges.
(2) The Copies made are very very dark in normal mode with adjusting the density level. How do i reset the exporsure level to be lighter at normal mode (default mode)?
Thanks & Regards
-   josephling67
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
Possible causes to correct are: 1) The original image might be too light or dark, adjust the exposure manually to compensate. 2) The copier might be in automatic exposure mode, adjust the automatic exposure manually. 3) The copier might be in photo mode, cancel the photo mode exposure.
Was this helpful?
Yes
No
Solution #2
posted on Jul 01, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the light AP
Popular Solutions for Standard Registar SD650 Color
Questions and Unsolved Problems for Standard Registar SD650 Color
Do you recommend Standard Registar SD650 Color Copier?
Answer
Answer
Our Brother HL 1240 Printer has a paperjam behind the door in the back of the printer. It cannot be... (More)
Answer
Xerox DocuColor 6060 keeps coming up with Subsystem Fault 009-363 upon warm-up. Have scrolled... (More)
Answer
B4250 PRINTER PICKS UP PAPER THEN ERRORS , WILL NOT CONTINUE, CAN PULL PAPER BACK OUT , OPEN AND... (More)
Answer
My Hp 2550 Printer is orinting Prodomiatley RED.I have only recently spent $240 replacing the 3... (More)
Answer
My cannon mp190 misfeeds and flashes E 2 on the LED what can I do?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Standard Registar SD650 Color...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1496
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
