Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
How do I remove the grate on the bottom to clean the coils
Bought a Kenmore side by side with the freezer on the bottom. got no insruction book. Need to clean the coils underneath the refrigerator. There is a plastic cover on the across verythe bottom front under the freezer I dont know how to remove it to clean the coils. Is the a release I dont see. I have tired and am afraid it will break if I force it. Pleaqse help
    Scholar:
  • 31 Answers
They are usually held in with clips that snap in and out. This is especially true if you don't see any visible screws. Give it a good tug on one side and see if it pops out.
Posted on Jan 07, 2009
Kenmore Elite series side by side refrigerator serial # 79571033010
Probably low on freon(which means a leak) or a blockage in sealed system. Both costly repairs.
Dec 03, 2017 | Kenmore Refrigerators
My Kenmore Elite side by side refrigerator was blowing very warm air out of the grate at the bottom and the temp on the display in the fridge is rising. I also noticed the on the surface of the divider...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 11, 2011 | Kenmore Side by Side Refrigerator
We have side by side Kenmore and on freezer side we are getting prozen water under the slide out drawers on the bottom on interior. We have cleaned it out and it refreezes and when we turned off water to...
Your drain line is frozen and not allowing the defrost water to drain to the pan below. The drain hole is at the bottom of the evaporator coil in the freezer behind the metal rear panel. You may need to remove the panel to access it. You can use hot water to thaw it out and you should be in good shape.
Kelly
Mar 24, 2011 | Kenmore Side by Side Refrigerator
Kenmore Freezer Model 253.26732104 Compressor
the defrost timer may need reseting. when the defrost is on, it cuts power to the compressor so they don't run at the same time. it's usually behind the bottom front grate on the right side. also check the main circuit board. there's a fuse on it.
Jul 31, 2009 | Kenmore Freezers
Water leaking from bottom of kenmore side by side fridge.
THE FREEZER MAY BE FROZEN UNDERNEATH THE COILS. UNPLUG THE KENMORE AND GET A VACUMM CLEANER OR A SHOP VAC AND CLEAN THE COILS ON THE BOTTOM OF THE FRIDGE. AFTER THAT REMOVE ALL ITEMS FROM THE FREEZER AND USE A SCREW DRIVER TO REMOVE THE PANELS FROM THE INSIDE OF THE FREEZER TO LOCATE THE COILS (INSIDE) THEY MAY NEED TO BE DEFROSTED DUE TO THE LENT BUILD-UP ON THE (UNDERSIDE) BOTTOM OF THE FRIDGE... HOPE THIS HELPS
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer on bottom works fine, fridge part dosnt
it sounds like the timer is going bad.... there is a timer that runs the fridge for 6 hrs. and defrosts for 20 mins. if the contacts are pitted ,it will run for shorted periods ..... this timer can be located anywhere from behind the unit where the compressor is to inside the regrigerator compartment ...
May 23, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Removing grate cover to get to the coils so they can be cleaned
MOST GRATES JUST POP OFF,DEPENDING ON YOUR FRIG. MODEL,YOUR COILS ARE ON THE BACK BOTTON BESDIE THE COMP. OR RUN SIDE TO SIDE A LONG THE FRONT,YOU REALLY HAVE TO GET THE GRATE OFF AND LOOK UNDER TO SEE WHERE YOURS ARE,IT IS
IMPORTANT TO CLEAN THEM ONCE A YEAR-MIKE
Mar 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator/freezer
Seems that the condensate drain is clogged/frozen.. If there is a bottom storage bin on the freezer side, remove it. There should be a removeable panel on the back freezer wall. If you can safely remove it then do so. Look for an accumilation of ice behind the panel, under the evaporator coil. Do not attempt to do this unless you have a good mechanical aptitude. One other thing you may try is to clean the coil underneath the refrigerator. This can be quite difficult as the unit must be tilted in such a way as to gain access. The coil there is most likely covered in dirty hairballs. Once the coil is clean, let the unit defrost overnight. Once again, do not attempt any of these steps unless you are certain you can handle it. Perhaps it would be best to call a qualified service tech.
Sep 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
224 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
