Question about Xerox FaxCentre F110 Plain Paper Laser
Hi how do I turn of tx and rx reports on faxcentre F110/
  • jane73 Dec 12, 2008
    Thank you, but my question was obviously not clear. I mean how to turn off the log of faxes sent that it automatically prints afetr every 30 faxes or so? Many thanks for your help.
    President:
  • 2,072 Answers
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Posted on Dec 11, 2008
  • Rick Kasper Dec 12, 2008
    I am sorry I misunderstood. The Journal can't be shut off on that product. The firmware automatically prints one every 30 transmits or receives.
I would like to block all incoming faxes on the faxcentre f110 so that it is an outgoing fax only, how do i do this?
You don't really need to block incoming faxes, but just set the machine not to automatically answer them. This figure is from the manual:
Press the MODE button until you see MANUAL displayed. In manual mode you need to answer and start receiving a fax yourself from the machine.
You can download a copy of the user manual from Xerox if you need it.
Dec 17, 2010 | Xerox FaxCentre F110 Plain Paper Laser
Flashing cursor on a Xerox F110
Most likely the Low Voltage power supply has failed. I have seen this a couple of times on that product.
Dec 17, 2009 | Xerox FaxCentre F110 Plain Paper Laser
How do i print activity report from canonL100
Press the MONITOR BUTTON,it is the button with the block and a eye sign in it.TX RX RESULT will be displayed.Press the arrow down ones PRINT REPORT will be displayed,press ok,TX RESULD will be displayed.By pressing the arrow down you can choose beteen RX,TX and ACTIVITY reports Press ok and it will print out.
Aug 19, 2009 | Office Equipment & Supplies
Xerox FaxCentre F110, both red and green light on
Did you ever figure this one out? I'm having the same issue
Feb 23, 2009 | Xerox FaxCentre F110 Plain Paper Laser
F110 new cartridge, insert card, but card expired?
You will have to exchange it. If you got it from Xerox they will send you a new one, or exchange it as defective. That is very unfortunate.
Jan 23, 2009 | Xerox FaxCentre F110 Plain Paper Laser
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
How do I turn on the Fax conformation
you need to go into rx setting and turn rx report back to on,
and go to TX settings and turn Tx report on.
this can be found in menu, device settings, fax setting, (tx and rx report will be shown) change it from there
hope this helps
Oct 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax centre F110
Reset 02 means the fuser is not warming up.
Most likely a fuser failure of the overheat thermostadt.
Need to have the fuser replaced most likely.
Jan 03, 2008 | Xerox FaxCentre F110 Plain Paper Laser
BAD COPY
verify it is your fax not the sending one  by doing a copy, then do a report of some sort. this will show us if the fault is in the optics or in print mechanism, if report is ok then it is the optics (clean glass) but I doubt this is your problem I reckon you get a blank mark down your report and copy that being the case then the fault is no toner left in print cartridge, replace cart
Oct 16, 2007 | Xerox FaxCentre F110 Plain Paper Laser
Xerox FaxCentre F110 Plain Paper Laser Logo
435 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
