CD display "ERROR" after a few seconds and doesn't play or rotate. Pressing cd/Disc Skip will clear the message so that the open/close button will function. I can put in 2 CDs but the tray doesn'r rotate for a 3rd one.
If i insert a CD then press the play/pause then within a few 4-5 seconds the "ERROR" message appears amd to get the CDs out I have to press the cd/disc skip again.
I did not try to use the CD when I first received the unit so now it is a few months old. The other features of the unit works just fine.
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Hello If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button. Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads...
prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Try unplugging the unit, then remove the cover. Take a cotton swab, wet one end with glass cleaner, and clean the lens on the laser assembly. Use the other end to dry it off and finish cleaning. Wipe very gently, do not press down hard on the lens.
This problem is usually (not always) caused by dust and smog accumulating on the lens, preventing the laser from reading the disc. Symptoms are skipping, spinning and not reading, or "no disc" errors.
This problem is usually caused by dust or smog accumulating on the laser lens assembly. Unplug the unit and remove the top cover. Take a cotton swab and wet one end with glass cleaner. Wipe it gently across the lens (do not apply pressure). Use the other end of the swab to dry the lens. Reassemble the unit and test for skipping or non-playing discs.
