Beeps On Boot
Good Morning, I have a very old machine that I would like to keep running to show Windows 3.11 and a DOS based Autocad. Well, when it boots up, there is no screen and it beeps about 7 or 8 times. What could the problem be? It might even beep 9 times since it does it so rapidly. Please Help
  • 1 more comment
  • bruce_fourma Dec 11, 2008
    Yes, I tried replacing the video card. That worked, but now I have three beeps, which I know is memory. I will try to reseat them, but trying to find sims is tough. Thank you.
    Yes, I remember that very well. It is just that I only have the two sets of 32. I would hate to see any of it going bad. Do you know of anyone that still sells sims?
    LOL No worries. Yes, I have been around for a while, but couldn't remember what the 7 beeps meant. It has been a while. This machine is older than my oldest daughter, so I would like to keep it running. Granted, I know one of these days, I will have to give up the ghost, but I am not ready as of yet.
    President:
  • 2,110 Answers
It might be the ram problem so try to change ram,if not solved then try to remove any PCI device...
Posted on Dec 11, 2008
  • 38 Answers
Sounds like it could either be a video card error or the bios rom chip is faulty, first try to rplace the video card, if you still have the error, replacec the cmos battery or at the least take it off the mother board and leave the computer unplugged for about 10 minutes, then replace and start again, failing that the motherboard might be faulty which would have to be replaced.
also try different memory chips, although the code you describe doesn't pertain to ram error it may be the cause
  • Smoking_gnu
    Smoking_gnu Dec 11, 2008
    No problem, just remember to always insert sims in pairs, try removing one pair that are in to check which ones are not working, be methodical you might find you can run your system after removing some of them
  • Smoking_gnu
    Ebay is probably your best bet TBH
    or try amazon, just found this
    http://www.amazon.com/Axiom-8X32-60Ns-72...
    good for a start!
    didn't mean to sound patronizing on the ram front ;)
Boot manager is missing HP pavilion dv6 notebook windows 7
This sounds like a common issue. The boot manager file "NTLDR" Can become corrupt or go missing due to a few situations.
1) Shut down improperly
2) Virus
3) Bad hard disk
4) Windows being windows.
Too fix this simply use a windows 7 cd and boot from it.
Choose the Repair option and let it do its thing. If i recall there's also a repair startup option you can use aswell.
Windows repair usually fixes the problem but if that doesnt work you can also put the hard disk into another computer and copy over replacement boot loader files.
  • ntldr, the main boot loader itself
  • NTDETECT.COM, required for booting an NT-based OS, detects basic hardware information needed for successful boot
    Try that. The windows repair usually works but if you have to use the alternative and it doesnt work it could be your MBR. Windows repair also fixes this but theres an old command you can run from the dos shell of the cdrom "mbrfix or fixmbr" That will take care of it.
    Good Luck :)
    Jun 08, 2014 | HP Pavilion dv9000z Notebook
    Biostar TA790GXE 125M keeps shuting down when I boot windows, on SATA and IDE hard drives
    Run the Check Disk Utility.
    To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
    Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
    If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
    In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
    In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
    May 31, 2012 | Biostar TA790GXE 128M 5.x Motherboard
    Acerpower FH beeps when shuttimg down and stalls
    Which Operating System? You have some boot and system file issues.
    Try running the check disk utility.
    You might have to do a repair install of your operating system. The repair install will not lose any of your data, documents, music, pictures, videos or programs.
    May 18, 2012 | Computers & Internet
    Satelitte toshiba u405-s2824 loaded new bios now wont load windows keeps restarting
    Terrible sequence. You should load windows on the old bios the flash the new bios.
    Did the windows installation complete? What keeps restarting the windows installation or the boot process?
    If the boot process keeps restarting try running the check disk utility.
    To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
    Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
    If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
    In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
    In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
    May 02, 2012 | Toshiba Computers & Internet
    How can i fix missing os or unformatted active partition for lenovo y410?
    Have you used this system before successfully?
    If so it sounds like you might have a corrupt or missing boot or system file. You'll need a repair disk or system disk to fix it. You need to get to a dos prompt (black screen with white writing) and run the Check Disk command.
    Mar 31, 2012 | Lenovo 3000 Y410 Notebook
    CMOS battery replaced in laptop and it boot loops everytime showing OS option screen and safe-mode options no repair option shows
    You changed the CMOS Battery, did you go into the BIOS and set the correct Date and Time? If that fails try running the check disk utility because it sounds like your boot files or systems files are either missing something or has some corruption.
    Mar 28, 2012 | Computers & Internet
    I FORGET MY IBM THINKPAD LENOVO T60 BIOS PASSWORD, NOW HOW I ENTER IN BIOS. PLZ GUIDE ME. S.VIRANI
    Hi
    Remove to your BIOS password download the CmosPwd, and follow the mention below instruction.
    Typical Usage for DOS and all Windows users:
    1) Identify your BIOS manufacturer (usually displayed at boot-up)
    2) Start in DOS, or start a DOS session in Windows 95/98/ME. For Windows NT or Windows 2000 boot from a DOS or Windows 95/98 boot disk (you can find boot disks at www.AnswersThatWork.com), and run CMOSPWD from your boot floppy (or another floppy).
    3) C: [Enter] cd CMOSPWD [Enter]
    4) Type CMOSPWD at the DOS prompt and press Enter.
    5) CMOSPWD will display a list of possibilities. Use the possibilities itemised against your BIOS manufacturer. Remember :
    a) For AWARD BIOSes, use the Numeric Keypad (with NumLock ON).
    b) AWARD 4.50PG BIOS always accepts "AWARD_SW", or "d8on", or "589589".
    c) Old Phoenix BIOSes will accept "phoenix".
    6) If the standard method does not work, then try to kill the CMOS password with CMOSPWD /K (and press Enter), and then see if you can get into the CMOS without a password. If you can, you successfully "killed" the old CMOS password. DO NOT KILL THE CMOS ON LAPTOPS!
    Aug 03, 2011 | Computers & Internet
    Uninstalling vista
    Well i Suggest That You Should Install Windows XP On This System Because The Configuration Of Hardware Would Mess Up Everything In Case Of Windows Vista Installation..
    There are 2 ways of UNINSTALLING WINDOWS VISTA
    1) Using MS-DOS PROMPT and for that u need to have good expertise with the MS-DOS so that u can RUN DEBUG COMMAND on the hard drive
    2) Method Is Easy .. it is to install WINDOWS XP and after its installation WINDOWS VISTA would be uninstalled
    Temme if u need HELP in re-installing WINDOWS XP....
    May 28, 2009 | Dell Dimension 4600 PC Desktop
    NOT booting WINDOW XP
    Hey stanley154
    try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
    all the best
    zinja
    Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Installation problem
    Replace the hard drive with a new one. IT takes a standard IDE 2.6" laptop drive - I would try newegg.com they have pretty good prices probably about $100 for a 120gb drive.
    The hard drive is under the 3x4" cover on the bottomn of the machine.
    Dec 31, 2007 | HP Pavilion zd8000 Notebook
    Computers & Internet Logo
    129 people viewed this question
    David Payne
    David Payne
