HP 1740 popup of OSD Lockout
I have HP 1740 model monitor. last couple of days , every time i trying to open my monitor, OSD lockout popup and i can't move it or fix it.
  • saqr60 Feb 10, 2009
    i have sam proplem
    how i can fix it ?
Dont take apart the monitor!?!?! Hold the Menu button for about 15 seconds, the manual said 10 but i found by holding menu for 15 seconds it removes the OSD lockout.
Posted on May 22, 2009
  • 4 Answers
Hello everybody,
I know how to fix this, but it involves opening up the monitor....
First unplug the monitor and get all the cables out. Then get the monitor of its monitor stand, this is done by unscrewing the four screws at the back of the monitor stand.
Now you can pry open the case with a flat screwdriver. On the inside you see a small electronic board with the power switch and the other switches on it. These 'broken' or dirty switches are what causing the OSD lockout.
Get the small board out of it's bracket and use some ETHANOL or ALCOHOL (atleast 70% pure) to clean the switches, you just spray or drip the ethanol into/onto the switches. This will clean the switches of any grease residu. Then spray the switches with air out of an airspray can untill they are totally dry.
Now you can put everything together and voila! it is working again!! atleast it worked for me :):)
This fix will only work if the switches aren't broken but only dirty or a little bit stuck, if they are broken then you would have to solder new ones on the electronic switch board.
Good Luck!
Ralph S.
Posted on Dec 23, 2008
I find the only soluion for the OSD lockout message is to hold the power button down after it has been lit. I use a bulldog clip to do that. I think it is a crude way of doing this. But it helps in my case.
Posted on May 03, 2013
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
HP L2035 OSD Lockout and DVI lockouts
change micro switch in frount panel all
Mar 19, 2010 | HP L2035 20.10" LCD Monitor
OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Feb 14, 2010 | HP vp17 Monitor
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
How the unlock osd
OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
Nov 12, 2009 | HP vs15 15"LCD Flat Panel Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Mar 27, 2009 | HP w1907 LCD Monitor
MY HP 1740 FLAT SCREEN MONITOR IS SHOWING A OSD LOCKOUT WARNING
Might be this...
For an OSD Lockout message, press and hold the Menu button for 10 seconds.
For a Power Button Lockout message, press and hold the Power button for 10 seconds.
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3648453&prodTypeId=382087&objectID=c01508108
But then this post says he had to hold it down for 25-30 seconds...
http://h30434.www3.hp.com/psg/board/message?message.uid=59866
Mar 17, 2009 | HP Computers & Internet
Computers & Internet Logo
4,899 people viewed this question
David Payne
David Payne
