Question about Canon MVX330i Mini DV Digital Camcorder
Want to view my canon mvx330i camcorder through my tv
I have the canon av video/audio cable but not sure how to connect to my tv.
Thanks
Chris
    Problem Solver:
  • 10 Answers
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Posted on Mar 05, 2009
How do I connect my sharp camcorder model VL-E650U to my Samsung tv series 6 630 lcd tv to view the 8mm videos on my TV screen?
You will have to use AV cables and an adapter. The adapter looks like a scart cable connector, it is that shape , and it has 3 inputs
one red one white and one yellow. It should fit in a spare scart socket on the tv and the cables should attach to the camcorder.
Just program the video to a particular channel, you may have to consult your owners documentation to discover how this is done. Go to the channel, insert the tape and press play.
Jun 25, 2015 | Samsung Video Cameras
I have a quite old Canon MV400i camcorder, which I am unable to get any connection indication from my new PC when I connected by S video/S video cable, the same applies when connected by the AV in/out jack...
For a camera of the kind you have, you need an analogue video input card in the computer to accept the video input, and you need to play the video into the computer while the computer records it. The PC will not recognise the camera as such, using these AV connections, it will only see a video signal. You don't have to install anything relating to the camera on the computer, but you need software running on the computer that understands the video input card and can take the analogue input and store it in a file. Yes, I know the computer stores the videos on digital tape, but the connectors you are talking about are analogue, and so is the signal at that point.
I am not sure that your computer actually has a video input interface (unless you have installed one?). Sometimes display cards have s-video sockets that are actually output sockets. In any case, video input interface cards generally come with the software required to capture input- it won't be specific to the camera.
Oct 22, 2010 | Canon MV400i Mini DV Digital Camcorder
I have 4 samsung tvs. I want to connect camcorder
Get an RCA cable and connect the following to the back of your HDTV:
Yellow - Video
Red- Right Audio
White - Left Audio
The other end should be compatible with the Audio-Video output of your Camcorder... Like a small av-jack.
Jun 12, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Need to transfer order VCR-C tapes to DVD How
You will need to borrow or buy a DVD-Recorder, either way it's best to follow the manuals instructions on how to connect your camcorder (external device) to the DVD Recorder for Recording to DVD. Most camcorders come with a set of AV (audio/video) Cables for this purpose. On your camcorder you will find a little rubber door that houses the terminals to connect your cables to. Depending on how old your camcorder is you will find a Yellow (video) and a White (audio) and on the newer ones that have stereo capabilities...you will have a Red (audio), all these connections are video and audio Out-Inputs and should be connected to the Video and Audio "In" terminals on the back of the DVD Recorder. Now make sure your battery is fully charged (It's best here to use an AC Adapter for your power supply instead of your battery, which also usually comes with your camcorder if bought new.) and that your VCR-C tape is loaded and completely re-wound. Now if you want to watch this on your TV while you are recording to DVD...you'll need another set of AV Cables that come with a new DVD-Recorder, and hook these cables on the Out-terminals on the back of the DVD- Recorder and the other end of the cables to your TV's Video/Audio-IN terminals on the back of the set. Finally...Set your camcorder switch for Playback, turn on the DVD Recorder, And turn on your TV. Now you can go ahead and record all your VCR-C tapes to DVD! Any other questions? Contact me directly at over4dy@yahoo.com
Jul 29, 2009 | Video Cameras
Where do i connect the cable to the camcorder so i can view on the tv
you would take the black rca plug opposite end of the red white and yellow plug. plug it into the side of the camcorder it should say a/v out and have a hole to plug it in then take the red white and yellow plugs and plug them into a tv and it should say a/v in then switch the tv to audio video 1 or 2 and it should work
May 17, 2009 | Canon DC210 DVD Camcorder
Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
Jan 01, 2009 | Canon ZR900 Mini DV Camcorder
AV jack
YES YOU MAY EITHER WANNA REPLACE THE AV(STEREO VIDEO CABLE) OR IF U HAVE HAD IT LESS THAN 90 DAYS CALL CANON FOR A REPLACEMENT 800-828-4040
Nov 30, 2007 | Canon DC100 DVD Camcorder
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Watching tapes on TV
To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR). Once cabling is completed, follow either of these scenarios: When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control. # When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode. # Operate the TV as you normally do to see the signal coming from the VCR. Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
Canon MVX330i Mini DV Digital Camcorder Logo
130 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
