Question about GE (PSS26MSRSS) Side by Side Refrigerator
Unusual Fan noise on the freezer side
I have a GE Side by side, about 3 yrs old. Just recently there has been a loud whinning noise coming from the top of the freezer, i open the freezer and it sound as if the fan is running fast then slow and will not stop. I have unpluged the fridge only to have the same problem days later.
  • Anonymous Mar 21, 2014
    When the refrigerator is running some intermittent noise is heard coming from the fridge
I am a multiple victim of the same issue. The true problem is probably the fan motor. Mine was replaced twice already and is noisy again. I had a GE tech look at the issue, along with the frost/ice build up in the freezer and the erratic temp control in the fridge. Nothing was done for me under warranty and now I am paying. It seems to be a defect tha GE will not admit too, although a class action suit addressed some of these issues and the owners were compensated. The problem is my serial number was not included in the settlement. I am sure that GE/Hotpoint will never stand by these issues and we must learn to stay away from their products and any sub companies they own. Just bad business in America again!
Posted on Aug 22, 2007
    President:
  • 878 Answers
Matt, this model has a main board in back that controls the operation of the evap fan. This is a two speed, DC motor and the fan takes a least one minute to change speeds. Therefore any speed changes in less than a minute time is abnormal. I usually find that the board is causing the problem. If you're handy with a meter you can do some tests. On harness J2 on the control board (just below the top harneses) check the DC voltage on pins 3 and 8 reading from left to right. There should be at least 12VDC. If you find a fluctuation of voltage, your board is giving you the problem. Catriver...post back
Posted on Mar 05, 2007
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
Unusual fan noise
YOUR FREESER FAN IS GOING BAD ,REMOVE FREEZER PANEL TO EXPOSE FAN,HOLD FINGER ON FAN,RELEASE IF FAN DOES NOT START REPLACE,THANKS-MIKE
May 29, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
306 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
