Question about E-Machines M6811 Notebook
Suddenly, my screen is dull and dim
I rebotted my emachines M6811 an I can barely read the display. It is very dim... did I do something? is the a keyboard control for the display brightness?
  • DEVLCOBRA Jan 18, 2009
    dull screen
  • 38 Answers
There will be a brightness switch it will be a combination of the fn key and a key with a sun symbol and an up arrow on it (usually the up cursor key) if that doesn't work i'm afraid that your backlight or inverter has died, you can get replacement parts on ebay but if you havent done this sort of repair before it may be better to take it into a shop to do, unless you are still under warantee then the manufacturor has to repair/replace, its a good idea to get everything backed up off your Hard drive first.
double check that its the backlight by pluggin the laptop into an external monitor first as if it is a backlight issue it will display fine externally
hope that helps
Posted on Dec 11, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
You should be able to use function+f7 to dim and function+f8 to brighten.
Dim screen on HP. Any diagnostics I can run to isolate the problem?
The problem is in the inverter board, "located below the screen" or the backlight behind the LCD display is faulty. In most cases the inverter is the issue and replacement only option, "be aware that high voltage is present when running"
Apr 15, 2012 | HP Compaq nc6220 Notebook
My Emachine m6811 Laptop will not stay on
possible problem would be your processor or ram,
try to clean first your ram..
Aug 22, 2011 | eMachines M6811 Notebook
Screen dull on Janome mc 8000
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light
Janome Memory Craft 8000 LCD Backlight Replacement Kit
Mar 26, 2010 | Janome Memory Craft 5700
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
My emachines m6811 screen shows a poor quality
Sounds like the pc is set to a low pixel setting, try going to properties and adjust display settings.
ie. Right click on desktop image, click on Properties. WIndow will pop up, click on SETTINGS tab and adjust Screen Resolutions and/or Color Quality. That should make the change. Sometimes programs installed changes those settings. Good Luck!
Jul 15, 2009 | E-Machines M6811 Notebook
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
When I turn on my e-machines M6811 laptop I get 2 short POST beeps; no screen display. What does it mean?
Two beeps usually indicates a memory problem, try re-seating the RAM. You may need to purchase new RAM.
Good luck.
Mar 21, 2009 | eMachines M6811 Notebook
INSTALL XP ON EMACHINES M6811 WITHOUT CD
If you have another pc, network the two and share the cd drive of the other PC
Mar 07, 2009 | E-Machines M6811 Notebook
Laptop Screen Has Different color lines
screen fault, needs new one but if it doesn't happen to an external one.
hook up a normal pc screen to the side vga and see if the same is there, if the same then it's possibly the refresh rate is too high or a motherboard issue
Mar 02, 2009 | eMachines M6811 Notebook
E-Machines M6811 Notebook Logo
619 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
