Commissioned a Panasonic VL-G201 video intercom yesterday but even at it's darkest setting the monitor picture is so bright a person cannot be seen,and to-day is a dull day. Any suggestions
  • 3130 Answers
SOURCE: brightness
Yes there is, you can very carefully take off the back of front speaker grill and the wood cover behind this. There you will see several controls I think six total, three on the top and three right below it, you want to turn up whats called the three screen controls for the red blue and green but you will need a B & W picture on the TV so you can balance the greay scale. if you do not balance the grey scale the TV will not look good. if you do not think you can do this adjustment properly, please play it safe and call in a tech to do these adjustment for you. Good Luck
Posted on Mar 23, 2007
  • 5138 Answers
SOURCE: panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Posted on Feb 05, 2008
  • 4402 Answers
SOURCE: Mitsubishi WD52525 Brightness
Mitsubishi Caps cause dim Picture faulty capacitor issue in the WD-52525 does seem to be prevalent at the 3 yr mark. At the bottom of this long-winded comment is a link to another discussion forum similar to this one where we obtained the service manual, chassis replacement manual, and encouragement to attempt the repair ourselves. My husband and I are not experts by any means, but my husband did have the tools from previous electronics projects to solder. So we took a chance on looking for bad caps. And I am here to say that I’m so glad we did because there were 2 obviously swollen caps that were easy to replace. The picture is now even better than when the problem first occurred since we dusted the mirrors and screens while we were in there. NO WINDEX. Just a dry micro-fiber cloth did the trick. We'll probably do that annually going forward.
According to descriptions from several people, the symptoms and degrading image due to capacitor failure can take various forms. In our case, we had a lamp blow out 2 wks before the TV died. And I do mean blow out, not burn out. We didn't get any lamp replacement warning. It flat out blew the 1-yr old bulb to shards of glass inside the casing. We replaced the bulb with a brand new one like good stewards of a DLP HDTV should do. A mere couple of weeks later we watched the image degrade over the course of an hour through various stages until the new lamp simply wouldn't light anymore and there was a solid black screen and solid red lamp light even though the lamp itself was fine. The trouble-shooting diagnostics (pressing MENU and DEVICE buttons on the front panel) gave the 3-4 code indicating a lamp abnormality. But ultimately the problem was solved by replacing the C9A37 & C9A38 caps (both are 10V 3300M-M 105C). We did not have to do any repairs on lamp or ballast components. The cost of 2 new capacitors from Digi-Key including shipping was about $14.50.
Some folks have stated that they were able to do the repair without removing the power supply chassis from the back of the TV. That was not the case for us. It was a bit intimidating at first. But we disassembled everything, labeling as we went, so we could freely inspect and access all boards on the power supply. There are some tiny, very hard-to-reach connections between the power supply and the ballast. For this reason, I also recommend disassembling those ballast components from the frame. They're simply too fragile to force in a very tight space when reconnecting.
Lastly, I am still pleased with this TV. The color and clarity can not be rivaled in my opinion. Even after having gone through this, compared to the problems reported in some of the other threads on issues with whatever other brand name or model you pick, this is a relatively easy repair that can be DIY. This was why we went DLP in the first place. And it is why we will probably remain DLP fans until they aren't made anymore. But next time, we’ll go with an extended warranty for sure!
I do wish Mitsubishi would at least acknowledge the issue. I don't even expect any reimbursement, replacement, refund or anything like that. I'd just like to know that THEY know there's a simple problem to resolve and that they're doing something about it.
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
  • 8 Answers
SOURCE: my picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Posted on Mar 18, 2009
  • 1476 Answers
SOURCE: I replaced the lamp in my Sony KDS 55A3000 and the
I would check to make sure the lamp is inserted correctly. Usually there are rails for the assembly to slide on and it must be in the rails and inserted completely. Take it out and make sure there is nothing covering the path of light and the lens is clear and clean. Reinsert properly and carefully and try the unit again. You should also compare the old lamp and new lamp while you have it out and make sure they are identical and have the same light output in watts. This should solve your problems. If it does not I would return the lamp and ask for a new unit.
Thanks for using FixYa and the generous rating.
Posted on Sep 21, 2010
The KX-T7453 phone does not have a message function, you may have an associated voicemail on your system. Try dialing (on the intercom) extension 165 if you do not have a voicemail button. Are you trying to change the greeting for your individual phone or the main greeting people hear when they call your company?
This gets a lot more complicated and you should contact your vendor.
Dec 24, 2014 | Panasonic KX-T7453 Corded Phone
Monitor is set to 100%--still too dull
If the picture is dark, on screen brightness will not overcome this.
Apr 01, 2014 | IBM E74 Monitor
I just bought my first plasma tv. Its a panasonic tc-p42c2. I was wondering whats the best settings for picture display. Wont be playing any video games on it. I got a lcd for that.
The best setting really vary from person to person. However, on an average, the below settings seemed to be best :-
Picture mode: Custom
Contrast: 30
Brightness: 30
Color: 50
Tint: 0
Sharpness: 50
Color Temp.: Cool
Pixel Orbiter: Every 1 minutes
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 09, 2010 | Panasonic TCP42C2 42 in TV
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
Monitor Problem
lower right hand side are some monitor setting buttons.
They should let you configure your brightness and contrast,also sharpness.
One button may do an auto fix.
Also in your win control panel click on display, advanced. and set your resolution until your happy with the picture.
Jan 06, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
Acer AL11511
To even things out you need to use the controls on the monitor to lower the brightrnes. to acceptable levels. When playing a DVD there are seperate controls in the software and your graphics driver to adjust the Video Overly settings. Look for settings called gamma and brightness in the video overlay settings in the windows display properties panel. This should help even things out some. Deal is to crank down the brightness on the monitor and crank it up in the video settings in windows. It will make the DVD's brighter and rest of the time the regular screen darker.
Jun 26, 2007 | Acer AL1511 15" LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
