Question about Radio Shack Pro-95 Handheld Scanner
Squelch quit working in regular scan mode PRO-528
The Trunking mode works fine but regular scan mode remains on single channel as squelch never cuts out static. This is true for all freq ranges and banks. Trunking works great. Squelch in reg scan mode worked fine for a few weeks
  • wb1aij Dec 22, 2008
    I have the same problem with my squelch; it happened after about 4 or 5 years & was intermittant at first. You never knew if the squelch was going to work or not whenever you turned on the scanner. It is failing more & more often as time goes on. I need a schematic to try to fix it.
    Problem Solver:
  • 8 Answers
Just fixed my squelch problem; I don't know how it happened but Resistor 138 was burned & intermittant. It was so badly burned that I could not read the color code but it measured 880 ohms intermittantly. I replaced it with an 860 ohm carbon resistor & all seems well; time will tell. R-138 is located on the circuit board right behind the squelch potentiometer. R-139 is immediately behind the pot & R-138 is next to R-139. All I had to do is remove the 4 screws on the back of the case & the unit splits in half. I clipped the old resistor out leaving a bit of the old leads so I could solder in the new resistor without having to get to the backside of the circuit board. Scanner is working as I type this & I hope it does not burn out again. Hopefully this is the same problem in your scanner & an easy fix. Good luck.
Bob Tomlin
WB1AIJ
Posted on Dec 22, 2008
I can't turn off the squelch on my Radio Shack Digital Trunking scanner.
On all channels, or on one channel ? Some channels are "birdie" channels, check your user manual. Others are problem channels receiving false signals from computers, monitors, receivers, internet equipment, FAX machines, etc. If your in conventional mode, if in Digital mode the squelch is set by the processor, and I don't believe the squelch has any effect in that mode.
Sep 18, 2014 | Radio Communications
My squelch button stopped working on the BC898T Base Scanner
Trunking is designed this way. You wouldn't want to listen to the control channel data, or you would never hear any of the actual radio calls. It sounds like it is working as it should.
Oct 05, 2012 | Uniden BC898T Base Scanner
Last night was working fine - as it was on I noticed that the scanner was just stuck on one channel - I hit scan ( I have several channels programmed) It wouldnt scan. Then when I turned the squelch...
Hopefully Resetting or Initializing the scanner will clear the problem and get it working again for you. Instructions for these procedures are on page 38 and 39 of the scanner operating manual. If you don't have the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
May 24, 2011 | Radio Shack Pro-82 Scanner
Scanner locks on tower frequency
If you are using a trunking system, then it sounds like you just have it set for "FM" mode, instead of "MO" Motorola trunking. You will have to use your owners manual to see how to set up a trunking system by putting the control channel (tower) frequencies in a special mode, then it will work if it is a PRO 96, PRO 106, etc.
Aug 10, 2010 | Uniden Radio Communications
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
Have a Radio Shack PRO 2018 that stopped working properly,Scans but necver finds anything.adjust squelch and nothing but static so it is not the speaker.PLEASE HELP
Did your local public service switch to a digital system? If so, you cannot receive digital trunking on this radio. Ask at your local Radio Shack store, or a local ham radio operator who can help you out.
Jan 12, 2010 | Radio Shack Pro-2018 Scanner
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Programming channels
Hello ... IF YOU HAVE A COMPUTER YOU CAN MAKE PROGREMING, DETETINMG AND TRUNKING A BREEZE. IF NOT I FOUND THAT ALL FIRE AND POLICE TRUNKING ACTIVITIES ARE BETWEEN 840.0000 through 900.0000. WHEN YOU WANT TO SAVE A CHANEL TURN OFF RADIO AND TURN BACK ON SELECT THE DESIRED CHANNEL YOU WANT. THEN PRESS "PGM" AND ENTER YOUR FREQERNCY... PRESS ENTER AND IF YOU WANT TO ADD ANOTHER CAHANNEL ... HIT "PGM" AGAIN AND FREQ. AND ENTER. YOU CAN KEEP DOING THIS TILL YOUR DONE GROGRAMING .. THEN JUST HIT SCAN AND IT WILL SCAN ALL THE FREQ.S YOU HAVE ENTERED. HERE IS A SOFTWARE PROGRAM THAT CAN LOOK UP ALL FRQ ANYWHERE IN THE US AND WITHE A PLUGIN DOWN LOAD ALL THE CHANNELS. BuTel software home page ARC-433 software for Radioshack PRO-433 / PRO-528 / PRO-2051 'ARC433 is now available!' -------------------------------------------------------------------------------- ARC433 (US$ 29.95) is dedicated software for the RadioShack PRO433, PRO528 and PRO-2051 and is the most versatile software available for the Radio-shack PRO-433 / PRO-528 / PRo-2051. Screenshot from our memory editor: the most versatile memory editor available on the market: -------------------------------------------------------------------------------- Overview of options in ARC433: Order ARC433 now online using PayPal/credit card or call Santa at 1-800-SCANNER ARC433 supports the Radioshack PRO433, PRO528 and PRO2051 models in one single software package. ARC433 includes THE most versatile memory editor available on the market. Radioreference.com import option for conventional and trunk systems! Programming your scanner was never this easy! Enhanced CSV file import and 'mapper' Paste Frequencies DIRECTLY from any website using 'Paste Special' Setup channels in an easy, spreadsheet type interface. User Manual (45 pages, PDF file) Store Unlimited number of configurations on your harddisk. Copy/Move/Swap memory banks / memory channels Compatible with Windows 2000 / XP. All updates are free for registered users Easy cut/copy/paste data between channels and banks. Move channels up and down with quick move buttons Export CSV data Fill down/series option Full clipboard support for import/export data to/from other applications Easy data toggle with mouse double click or space bar or keyboard shortcuts Sort frequencies per bank Remove duplicate frequencies Easy Fill for setting up new banks in a few seconds (enter a start frequency and a step, and easyfill will calculate and fill the selected bank) Extra Dummy bank for storing temporary data while you are re-organizing your scanner channels. Print option System Requirements: Windows XP/2000/Vista PC interface cable 20-047 for USB or PC interface cable 20-289 for serial port Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final. Order ARC433 for PRO 433 / 528 now online using PayPal or a credit card or call 1-800-SCANNER. -------------------------------------------------------------------------------- Screenshots:
Apr 16, 2007 | Radio Shack Pro-95 Handheld Scanner
My 95 is way off - Freqs,Mode not working...Grrr!
mORE AND MORE POLICE AGENCIES ARE SWITCHING TO "DIGITAL TRUNKING". I CAN ONLY PICK UP PARTS OF MY LOCAL SHERIFFS STATIONS. RADIO SHACK HAS THE NEW dIGITAL TRUNKING SYSTEMS THEY COST ABOUT $500. I AM UP GRADING NOW. FOR TRUNKING ... WHEN YOU GET A ACTIVE CHANNELL KEEP HITTING THE RED TRUNK BUTTON TILL YOU SEE THE MOTOREOLA 5 NUMBEWR ID.THJEN HIT ENTER. I WANT THE NEW PROGRAMER THAT IS FAST ENOUGH TO FOLLOW DIGITAL HYPER-TRUNKING. ALL POLISE ARE GOING TO IT EVENTUALLY.
Sep 18, 2006 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
284 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
