Question about HP OfficeJet d145 InkJet Printer
My hp officejet d145 has a jammed carriage. It makes a terrible noise and will not move when the lid is raised.I am stuck and cannot perform any functions at all not even faxing. Any ideas would be very gratefully accepted
  • stephen626 Dec 11, 2008
    Many thanks for your suggestion. Unfortunately it didn't work as I was too worried about breaking it. I tried gently but to no avail.
I had a similar problem on my d145. The error code on my printer told me to open the door, latch the carriage, close the door, press enter, which did not correct the problem. Follow the recommendation from klhanson in solution #1 and clean the ink off of the copper contact on the white slide bar located below the right hand side of the carriage where it hits a blockage as it is prevented from sliding all the way back to the right side of the slide bar. Unplug the power and gently move the carriage to the left hand side of the slide bar out of the way. If the white slide bar will not retract back out of the way of the carriage to let the carriage slide back all the way to the right side, look for a small black latch located below the right side of the white slide bar. The black latch is attached to a small metal strip that also gets gummed up with ink and if it can't move back and forth, the white slide bar won't retract and move out of the way of the carriage. Use a small amount of alcohol on a Q-Tip and clean the metal strip attached to the black latch. Try to gently move the black latch back and forth with a small screw driver to free it up as you clean the metal strip. Plug the printer back in and hopefully the black latch will move back and down and let the white slide bar retract to the back and out of the way when the carriage starts to move. This process worked well for me, and it also eliminated the terrible noise. Also make sure your slide bar is vey clean. I hope this information is helpful.
Posted on Jan 31, 2009
There is a little white bar that blocks the cartridge from moving. On the surface of this bar is a copper contact. Try cleaning this contact. It worked for me, a lot of printer head residue had built up and prevented electrical contact.
Posted on Jan 02, 2009
  • 837 Answers
Sometimes if you unplug/remove power from printers you can manually move the carriage for access. but do it carefully .. you could break it. Good luck
Posted on Dec 11, 2008
Though i have no paper jam, it keeps on prompting Clear paper jam then touch ok. Also notice the carriage not moving from right to left ,its making a weird noise.seem paper feeder gear stuck but clear
Hi vidya kowlessur,
I would be happy to help you with your Officejet 7500A printer. I understand you are seeing a message prompting you to clear a paper jam, and the carriage is likely jammed. Please use the following 2 documents to troubleshoot the issue;
HP Officejet 7500A E910a and E910c Wide Format All in One Printers Out of...
Carriage Jam or 0X610000F6 Message Displays for HP Officejet 7500A E910a...
I hope this helps, but if the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 09, 2015 | HP Officejet 7500A Wide Format...
Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
How can i clear carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Jun 08, 2010 | HP Officejet 4355 All-In-One InkJet...
Carriage jam
Step 1: Move the carriage to the center manually if necessary If the carriage is stuck on the right or left side of the product, follow these steps to move the carriage to the center of the product.
Step 2: Check for a broken carriage chute
The carriage chute is the side wall of the carriage that holds a curved metal piece (the x-bias spring). A broken carriage chute might cause the carriage jam condition.
Step 3: Turn the product off and on again
Step 4: Clear any paper jam.
Step 5: Make sure that the control panel faceplate is correctly installed
Step 6: Plug the All-in-One directly into a wall outlet
Step 7: Perform a partial reset
Step 8: Print a self-test page
Step 9: Service the product. Now this model is outdated as per HP website.
Aug 23, 2009 | HP Officejet 7210 All-In-One InkJet...
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp officejet d145 carriage error & scanner failure
Re carriage error - suggest cleaning the encoder strip. this is the plastic strip running parallel to the drive belt but about 1 inch above it. They frequently become covered with ink spray and so are impossble to read by the carriage position detector.
Beware.
Only use cold water and be very gentle. also make sure you dry the strip thoroughly before switching the machine back on.
Re scanner problem 2 possibilities.
(1) make sure printer power cable is connected directly into wall socket not through an extension cable. This can reduce the voltage getting through to the scanner lamp.
(2) if that don,t work then I suggest you take the scanner apart and clean the reference strip. this is a white bar on the scanner glass which tells the machine what the light level is. This can be a bit tricky so if you've never done it before consult someone who has or get back in touch with me. HP don't want you to do this but it sometimes works.
Dec 11, 2008 | HP OfficeJet d145 InkJet Printer
Carriage Jam Error display on the LCD!
open the lid ,you will see the cartridge track(steel bar) look both end of the track you will find something stuck over there most likely paper chip
Dec 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge jam
There are clips under the feet, get a torch and u can align them both and push down at the same time, they will click in. To test it make sure there is only frontal and backward motion, one is out still if it moves side to side.
Jun 04, 2008 | HP OfficeJet d145 InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
161 people viewed this question
Ben Johnson
